> 2.7 case guru, save/scrap
930cabman
post Feb 20 2021, 07:41 AM
We are attempting fitting a 2.7 into our 1974 rustout hulk but have come across another hurtle. I have had a 2.7 kicking around for awhile and "assumed" we could go through it with new bearings/rings/..... and have a nice power plant. Not so quick there. The head stud issue is well known and I recently found when the magnesium cases are disassembled the crankshaft bores no longer return to a round/aligned condition.
I want to believe someone out there can get these magnesium cases in serviceable condition with good crank bores and good head stud bores.
thanks
930cabman
post May 16 2021, 06:05 PM
Ollies contacted me last week, they are back logged about 14 weeks. They explained the main bearing bores grow about 2 thou in the horizontal direction and shrinking about the same in the vertical dimension. They will take a few thou off the mating surfaces and rebore the mains to a standard bearing set.
Victory
930cabman   2.7 case guru   Feb 20 2021, 07:41 AM
gereed75   There are several places that do this. Ollie’s ...   Feb 20 2021, 08:00 AM
Luke M   We are attempting fitting a 2.7 into our 1974 rus...   Feb 20 2021, 08:17 AM
mate914   Your close to a lot of engine builders. Karl Hens ...   Feb 20 2021, 09:06 AM
brant   The machine work on a mag case adds 3k to the rebu...   Feb 20 2021, 09:06 AM
930cabman   The machine work on a mag case adds 3k to the reb...   Feb 20 2021, 01:38 PM
Superhawk996   Exactly, why would we invest in a magnesium case...   Feb 20 2021, 02:10 PM
mepstein   The machine work on a mag case adds 3k to the re...   Feb 20 2021, 03:30 PM
horizontally-opposed   For me, once you add in the durability, power, f...   Feb 21 2021, 02:28 PM
mepstein   Yea, unfortunately that’s the truth. Especially ...   Feb 20 2021, 09:29 AM
Superhawk996   Had all my 2.4L case work done by Ollies. All p...   Feb 20 2021, 10:30 AM
mb911   Had all my 2.4L case work done by Ollies. All ...   Feb 20 2021, 10:46 AM
sixnotfour   Has to be torqued together with the nose bearing...   Feb 20 2021, 12:06 PM
sixnotfour   I have a small main bearing 3.0 case 6k..... Care...   Feb 20 2021, 03:25 PM
914forme   You can always find another 2.2, 2.4, and 2.7L fro...   Feb 20 2021, 04:22 PM
930cabman   You can always find another 2.2, 2.4, and 2.7L fr...   Feb 20 2021, 05:11 PM
gereed75   Sorry that you had bad luck with the first and sec...   Feb 20 2021, 08:52 PM
davehg   My Ollie’s bill was closer to $4k for my 2....   Feb 20 2021, 10:12 PM
sixnotfour   numbers matching   Feb 21 2021, 12:16 AM
rick 918-S   numbers matching Wow that's cool!   Feb 21 2021, 06:14 AM
930cabman   numbers matching I suppose it's true, ...   Feb 21 2021, 08:28 AM
mepstein   numbers matching I suppose it's true, ...   Feb 21 2021, 08:56 AM
930cabman   [quote name='930cabman' post='2893282' date='Feb ...   Feb 21 2021, 03:01 PM
Mark Henry   numbers matching I suppose it's true, ...   Feb 21 2021, 11:33 AM
Superhawk996   In the grand scheme of maching up mag cases, ...   Feb 21 2021, 11:44 AM
jd74914   In the grand scheme of maching up mag cases, ...   Feb 22 2021, 01:29 PM
mepstein   In the grand scheme of maching up mag cases, ...   Feb 22 2021, 02:13 PM
sixnotfour   2.4 mag ,,best engine ever.. Next week .I'll b...   Feb 21 2021, 12:26 PM
sixnotfour   12,500 https://noonanrace.com/products/911-porsche...   Feb 21 2021, 02:38 PM
horizontally-opposed   12,500 https://noonanrace.com/products/911-porsch...   Feb 21 2021, 03:07 PM
stownsen914   Pretty sure that ITG small bore case pictured abov...   Feb 22 2021, 11:32 AM
bahnzai   Cabman, I have a ‘67 sand cast aluminum case eng...   Feb 23 2021, 03:53 AM
930cabman   Spend an hour or building a shipping crate to send...   Mar 1 2021, 04:57 PM
Superhawk996   Spend an hour or building a shipping crate to sen...   Mar 1 2021, 06:00 PM
930cabman   Ollies contacted me last week, they are back logge...   May 16 2021, 06:05 PM
rgalla9146   Could you keep us posted on turn-around and itemis...   May 17 2021, 04:32 AM
930cabman   Could you keep us posted on turn-around and itemi...   May 17 2021, 05:21 AM
- Lo-Fi Version Time is now: 29th October 2026 - 12:02 PM
