> LED headlight bulb install, Vintage Car LED VC 4000
gereed75
post Aug 26 2018, 07:11 PM
These lights are the second to highest in their product line. Chose them because they are preassembled into an H4 lens and do not use a fan.
This started as a 1 hour project that as usual turned into a 4 hour thing. After fighting nearly 50 year old screws the biggest issue became where to mount the circuit board box that is part of the assembly. First impression is it should be easy, but there is really not that much room in the headlight bucket as the assembly rotates up and down and the placement is not inconsequential.
Not inconsequential because one placement caught my plastic trim bucket and caused a stress crack. Bummer as these are original white ones on my '70 car.
At any rate, I ended up wrap tying onto the bracket that holds the spring. This position is a good fit. and remains out of the way as the assembly moves through its motion. Pix below.
Maybe this will save someone else some time (and a cracked plastic trim bucket).
Warning: Many wrap ties died in the completion of this project.
Oh yea, great product, low beams project a very diffuse pattern that lights a big area in front of the car. High beams are very effective. Makes night driving a whole new and safer experience. NICE!!
Cairo94507
post May 17 2021, 05:52 PM
Michael
@horizontally-opposed So I got a chance to drive with these at 0500 today. They throw some great light. I would say they are at least as bright as the GE Nighthawks and may even be brighter. I did note they were a bit high so I will adjust them down. I do not want to offend on-coming drivers. (IMG:style_emoticons/default/sunglasses.gif)
@gereed75 Thanks so much for the help with this project. These lights look perfect in the car. I had them in my last 6, 30 years ago, but that was when you still had to run the 80/100 bulbs and a relay. Even then, they did not light like these. (IMG:style_emoticons/default/beerchug.gif)
gereed75   LED headlight bulb install   Aug 26 2018, 07:11 PM
Cairo94507   I just received a set of these lights. I will tac...   May 13 2021, 12:11 PM
JeffBowlsby   Any issues with your hi/lo beam selector relay aft...   May 13 2021, 12:16 PM
Cairo94507   Hi Jeff, I actually plugged mine in just to test ...   May 13 2021, 12:41 PM
horizontally-opposed   …one placement caught my plastic trim bucket an...   May 13 2021, 12:44 PM
Montreal914   Eventually, I found these For $29, curios...   May 16 2021, 07:18 PM
Cairo94507   OK, so I tacked this today after reviewing @geree...   May 16 2021, 03:57 PM
dr.tim   Nice! I've been looking for a good 5.75...   May 16 2021, 04:17 PM
horizontally-opposed   OK, so I tacked this today after reviewing [b]@[...   May 16 2021, 06:25 PM
Cairo94507   @horizontally-opposed Thanks for the compliments....   May 16 2021, 09:35 PM
gereed75   Looking good mike. Glad to hear that the location...   May 17 2021, 06:42 AM
Cairo94507   @horizontally-opposed So I got a chance to drive...   May 17 2021, 05:52 PM
horizontally-opposed   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 17 2021, 09:02 PM
Cairo94507   The jury may be out for quite some time on that is...   May 17 2021, 09:05 PM
DC_neun_vierzehn   Thanks for sharing this info. I'm curious ......   May 17 2021, 09:25 PM
anderssj   Thanks for sharing this info. I'm curious .....   May 18 2021, 09:51 AM
DC_neun_vierzehn   Thanks for sharing this info. I'm curious .....   Jun 2 2021, 04:48 PM
Cairo94507   @DC_nuen_vierzehn I am not sure but the H4 headlig...   May 18 2021, 06:56 AM
gereed75   I suspect they drop in to “standard” H4’s. ...   May 18 2021, 10:29 AM
DC_neun_vierzehn   I suspect they drop in to “standard” H4’s. ...   Jun 1 2021, 10:11 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:38 PM
