Chaznaster |
Member ![]() ![]() Group: Members Posts: 305 Joined: 22-November 15 From: Concord, MA Member No.: 19,389 Region Association: North East States ![]() ![]() |
Hi All. I was working towards getting on the road formally this spring and seem to have caused a problem while digging around the engine bay.
It's a 74 1.8 with a single Weber progressive and an 009 distributor (I know nobody likes that setup ...) and Pertronix Ignitor. We have had it running (adjusted valves and timed it) and even put a few miles on it over the last few weeks. Today, out of interest and while trying to find out my Pertronix model number, I took the cap off the dizzy, pulled the rotor and magnetic sleeve and took out the Pertronix. There was no part number (ugh). I put it all back together (it has been running, albeit not well). When starting, I got a bright flash above the engine (!) and the car tried to run but it will not idle and backfires like crazy. So much so that I am not comfortable trying to start it again. (IMG:style_emoticons/default/confused24.gif) I did check all the wires and plugs and all seems OK. I think the Pertronix is still working (it does fire). Could removing and replacing that part mess with timing or hurt the unit itself? I cannot see why but it is running like the timing is waaayyyy off. Does anyone here have any ideas on what I might have done to cause it to not run well. How about ideas of what I might do to get back on track? My only thought is to go back to points, static time it to start and go from there ... I really appreciate the help! |
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
I just had my first run in with faulty pertronix svda. I had been neglecting my silver 60 beetle. I decided to put fresh rubber and get it back to decent driving condition. Cleaned out the 34 pict 3. Couldn't get it running right. Swapped out the carb, still not right. Finally started messing with pulling the plugs and one was not firing. I even swapped wires l, nope. Swapped it out for my old known working 009 and she was running on all 4. This one is only 6 Mo old and has never really been run. I was pretty amazed. Sending it out to pertronix to be fixed.
Lo-Fi Version | Time is now: 17th June 2024 - 06:42 AM |
