Carburator selection??, I am having a hard time deciding! |
jporsche914 |
Dec 30 2004, 08:47 PM
Member Group: Members Posts: 149 Joined: 9-March 04 From: colorado, springs Member No.: 1,769 |
I want to replace my old fuel injection with some carbs. I just dont know if i want the 40mm idf webers or the smaller 34mm ict weber carbs and i was wondering if you guys could help me decide what would work best. I have a completely stock 1972 1.7L motor. I live in colorado so the extra air would help i just dont know how well the 40mm will work well on a stock motor. I have read that i should have no problem with running the bigger carbs but on other websites the 34mm where recommended over the 40mm. I deffinentally want more horespower and i dont plan of keeping the motor stock forever and i plan on doing 2.0L exhaust and ignition before i put the carbs on. What do you guys think i should get??
Thanks alot, James |
lapuwali |
Dec 30 2004, 09:42 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
If you really must go with carbs, the 40 IDFs will support more power later. The ICTs will start to choke the engine fairly early. Really, the right choice is aftermarket fuel injection, though. Leave the D-Jet on there until you actually do something that requires you change it. Then, go with Kit Carlson if it's available, or SDS if it's not, or Megasquirt it if you have the DIY skills.
Lo-Fi Version | Time is now: 31st May 2024 - 09:38 PM |
