> Intermittent lean issue, causes stalling / unstable idle *Update: Bad ECU?*
rjames
post May 16 2021, 04:41 PM
I'm made of metal
Forgive me for starting a new thread that is really just a continuation of a thread I started last year for this same issue. I've tried a couple of new things since then with no progress and figured I'd start a new thread to consolidate everything I've tried so far on one post. (I also put a link at the end of that thread to this one).
Symptoms:
Car will intermittently go into a very lean state causing the power to fluctuate, RPMs to fluctuate at idle and often stall if not opening the throttle a fair amount. Usually happens when engine is warm, but will go away mysteriously on it's own- usually after over enriching the air/fuel mixture and running in that way for several minutes.
I’ve determined it’s going lean because when this happens unplugging the TS1 / Air temp sensor and the surging / staling will cease. (Unplugging the TS1 according to pbanders site enriches the fuel mixture)
Or I can dial the ECU or MPS for a richer mixture which will also solve the issue to certain degrees, but when the issue mysteriously goes away the fuel mixture is too rich.
Symptoms are similar to when an MPS diaphragm fails. In fact, the car was running fine up until about 3 years ago when the MPS failed. I bought a rebuilt / recalibrated one from Jeff B. The car wouldn’t start with the rebuilt MPS because it was too lean (or rich, I can’t remember). I adjusted it, it started, I adjusted the AFR using a wide band sensor and ever since it’s had this intermittent issue.
Things I’ve done to try and solve the issue:
-Ensured correct matching ECU, MPS and CHT sensor.
-Have tried a correct # spare ECU
-New CHT
-Verified CHT is in spec both when engine is cold and warm. (I checked the CHT when the lean condition happened and it measured 78 ohms).
-Installed 123 distributor (issue also happens on stock distributor). I’m running retard on distributor, but have tried without.
-Installed new coil with the 123 distributor. Issue happens with old (stock) coil, too.
-Replaced all vacuum lines and verified they are hooked up correctly.
-Cleaned and flow tested injectors
-New injector seals
-Installed fuel pressure gauge in engine compartment- ~28psi. Reading is constant even when surging/stalling happens.
-New intake runner seals
-New intake runner gaskets
-New throttle body gasket
-Swapped throttle body with NOS model.
-Verified no vacuum leaks with smoke test.
-Verified AAR is opening/closing correctly.
-Verified the decel valve is opening/closing correctly.
-New injection harness
-New ignition harness
-Swapped relay board and verified continuity on all connections.
-Tried a spare rebuilt MPS that hold vacuum
-Manifold vacuum is constant at 15-17 HG
-Smoke test didn't reveal any leaks.
-Verified decal value is functioning correctly
-Monitoring the AFR using wide band sensor.
-Calibrated throttle position sensor. Tracks look good. (Unplugging the TPS has no effect when issue is happening)
-Verified grounds from the FI harness, under the relay board and ground strap on tranny is good.
-New odyssey battery (verified voltage is good)
-Verified timing and valves are adjusted to spec.
Misc info:
-Setting the idle above 13:1 at idle or thereabouts puts the idle speed at 1100rpm, and it will hunt unless you richen up the mixture, either with the ECU knob.
-Throttle body idle screw is all the way in to keep the idle at ~ 1000rpm. Verified that air gets past the idle screw from above the butterfly. Apparently not an uncommon issue according to others. Others report having a hard time getting the idle below 1000 with the 123 ignition.
-Compression is low on cylinders 1 & 2: 110, On cyl 3 & 4: 131
-Open AAR valve doesn't increase engine RPM when engine is cold. Verified AAR is opening. However, plugging the hose that runs from the AAR to the airbox will stall the engine until it's warmed up. (AAR closes as it should then)
Superhawk996
post May 20 2021, 12:50 PM
Pretty comprehensive list. (IMG:style_emoticons/default/biggrin.gif)
I know you said you smoke tested it - How sure are you? Have you been able to smoke test it when the issue is ocurring?
Didn't Zach just find a loose throttle shaft causing similar intermittent issues?
When you say it goes very lean, what is the AFR when that is occuring? Does that give any insight into how much excess air is entering somwhere?
Also, since you say disconnecting the ambient temp sensor TS1 helps, are you monitoring the resistance of that TS1 temp sensor when it is occuring? Could that sensor itself be going intermittent?
rjames
post May 21 2021, 02:24 AM
I'm made of metal
Thanks for the response. I'm not sure of anything anymore. (IMG:style_emoticons/default/biggrin.gif)
I was thinking about smoke testing it again. That's probably worth doing again, although wouldn't a vacuum leak with DJet result in higher rpms at idle and not a surging/stalling condition?
When you say it goes very lean, what is the AFR when that is occuring? Does that give any insight into how much excess air is entering somewhere?
When it goes lean, it fluctuates from lean to rich pretty quickly- the idle hunts from ~1100 to almost 0 (lean), and then will stall after several oscillations if I don't richen the mixture, similar to what happens if you turned the ECU knob all the ways counter clockwise. AFR gauge tries to keep up but goes up and down with the idle surge and goes past 16:1 when the RPM drop, and after several cycles will stall. I can keep it running if I keep the throttle open, but power is way down and I can still feel it oscillating.
Then there are times where I'll be driving along fine at low or high speeds with no hint that anything is wrong-AFR even looks good, but if I put it into neutral the car will stall. This is also intermittent, but when it does happen it's hard to start without opening the throttle all of the way, and then the idle oscillation behavior happens.
I don't think so, because when I unplug it and then adjust the AFR accordingly, the lean issue/hunting idle/low power/stalling still happens.
I was really hoping it was just a simple fuel delivery issue, but the gauge reads a constant 28 psi at all times.
The characteristics really seem like a bad MPS (I have 2 that hold vacuum that I've already tried swapping) or a bad CHT. My CHT reading was 70 ohms last time this happened. Is that too low? Pbanders site says it should be less than 100 ohms with a hot engine but doesn't cite specific numbers. I've tried swapping the CHT out too though. :/
Superhawk996
post May 21 2021, 08:54 AM
QUOTE(rjames @ May 21 2021, 04:24 AM) *
This seems like a really important clue. So if I understand your description correctly, a rapid change in load (i.e manifold pressure) can't be handled properly.
Maybe lends some concern for a MPS like others reported that had hairline cracking of the diaphram yet it still holds vacuum. Would be more concerning but I think you seemed to have that covered via rebuilt unit and same behavior with a separate MPS.
On the other side of that would be the TPS sensor properly reading a return to closed throttle postions (assumed in neutral) and the fact that it doesn't want to restart with a closed throttle. But you seemed to have that one covered too with trace check and new harness.
When things are intermittent I tend to lean toward electrical issues. Yes, intermittent issues occurs with mechanical devices but less common.
Any chance that you can drive and leave the ECU connector accessible and unplug and replug it when the issue is occuring and then see if it clears up? Probably dependent on how often this is happening and I hate to have you driving around with it unsecured for long.
rjames   Intermittent lean issue   May 16 2021, 04:41 PM
Rider914   Fuel Pressure? Edit: Nevermind ha   May 20 2021, 12:18 PM
Superhawk996   Pretty comprehensive list. :D I know you said y...   May 20 2021, 12:50 PM
rjames   Thanks for the response. I'm not sure of any...   May 21 2021, 02:24 AM
Superhawk996   Then there are times where I'll be driving a...   May 21 2021, 08:54 AM
Superhawk996   My CHT reading was 70 ohms last time this happene...   May 21 2021, 09:12 AM
Superhawk996   Thanks for the response. I'm not sure of an...   May 21 2021, 09:34 AM
wonkipop   i'm unsure what type of EFI you have. but i h...   May 21 2021, 03:38 AM
rjames   I've tried two different decel valves, adjust...   May 21 2021, 02:48 PM
Superhawk996   I like a good mystery. You've really got th...   May 21 2021, 03:42 PM
rjames   Update: I may have tracked down my car's inte...   Jun 21 2021, 03:07 PM
BeatNavy   Hey Robert -- Cautious :Qarl: (again). I hope y...   Jun 21 2021, 03:13 PM
JeffBowlsby   Double double…   Jun 21 2021, 04:16 PM
JeffBowlsby   Hey Bob, if you decide to toss your bad ECU, pleas...   Jun 21 2021, 04:17 PM
Jim C   Yes, they do go bad. The one in my car when I purc...   Jun 23 2021, 07:27 AM
rjames   Yes, they do go bad. The one in my car when I pur...   Jun 23 2021, 09:58 AM
rjames   Happy to report that a replacement ECU seems to ha...   Jun 26 2021, 11:16 PM
BeatNavy   :first: :first: and a :Qarl: Good stuff, Robe...   Jun 27 2021, 04:58 AM
- Lo-Fi Version Time is now: 8th July 2025 - 06:23 PM
