Head Ache |
Head Ache |
bkrantz |
May 24 2021, 07:37 PM
914 Guru Group: Members Posts: 7,791 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
As I showed in my rebuild thread, I found one of my cylinder heads with an insert for one exhaust stud, but installed at an angle. The other head has one oversize stud hole (9mm?).
My first thoughts: remove the insert and inspect the hole. I may attempt to drill a larger hole at the proper angle and install a bigger insert. If I do that, I may do the same for the other head, which will be the same hole position. Comments? Attached thumbnail(s) |
infraredcalvin |
May 24 2021, 09:57 PM
Distracted Member Group: Members Posts: 1,523 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Look to have plenty of meat, you definitely need straight studs otherwise you won’t get headers/heat exchangers on.
Lo-Fi Version | Time is now: 1st June 2024 - 02:00 AM |
