Head Ache |
Head Ache |
bkrantz |
May 24 2021, 07:37 PM
914 Guru Group: Members Posts: 7,809 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
As I showed in my rebuild thread, I found one of my cylinder heads with an insert for one exhaust stud, but installed at an angle. The other head has one oversize stud hole (9mm?).
My first thoughts: remove the insert and inspect the hole. I may attempt to drill a larger hole at the proper angle and install a bigger insert. If I do that, I may do the same for the other head, which will be the same hole position. Comments? Attached thumbnail(s) |
JamesM |
May 25 2021, 12:24 AM
Senior Member Group: Members Posts: 1,921 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Comments? How much money you looking to spend? Quite a few ways you could go but that all depends on your goals here. The safest bet, get brand new heads, but that obviously isnt an option for everyone. Frugal approach? Assuming you are not looking to have any other work done on the heads, and assuming the insert is the solid style and not a heli-coil, screw a stud and test fit your heat exchangers on the bench. If the stud is still angled well enough to let the heat exchangers slide on properly then I would say that may be the best you could hope for with that head. If you have the proper setup to do so you could attempt to re-drill it straighter and run an oversized insert, but that could be a gamble as well, especially if the current insert is actually functional as is. Personal opinion here, but anything beyond that requiring welding on the head I would just get new (as in brand new) heads. Exhaust stud issues may be my least favorite thing to deal with on 914s |
Lo-Fi Version | Time is now: 13th June 2024 - 05:54 PM |
