Head Ache |
Head Ache |
bkrantz |
May 24 2021, 07:37 PM
914 Guru Group: Members Posts: 7,801 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
As I showed in my rebuild thread, I found one of my cylinder heads with an insert for one exhaust stud, but installed at an angle. The other head has one oversize stud hole (9mm?).
My first thoughts: remove the insert and inspect the hole. I may attempt to drill a larger hole at the proper angle and install a bigger insert. If I do that, I may do the same for the other head, which will be the same hole position. Comments? Attached thumbnail(s) |
Front yard mechanic |
May 25 2021, 06:59 PM
Senior Member Group: Members Posts: 1,171 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Bolt it up and run it
Lo-Fi Version | Time is now: 6th June 2024 - 11:37 AM |
