Head Ache |
Head Ache |
bkrantz |
May 24 2021, 07:37 PM
914 Guru Group: Members Posts: 7,791 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
As I showed in my rebuild thread, I found one of my cylinder heads with an insert for one exhaust stud, but installed at an angle. The other head has one oversize stud hole (9mm?).
My first thoughts: remove the insert and inspect the hole. I may attempt to drill a larger hole at the proper angle and install a bigger insert. If I do that, I may do the same for the other head, which will be the same hole position. Comments? Attached thumbnail(s) |
bkrantz |
May 28 2021, 04:08 PM
I found a machine shop owner that is willing to try removing the insert, welding the hole, and re-drilling for the stud. But he needs an exhaust to be sure the stud position is correct.
Can this be done with the short 75-76 exhaust pipe section? Any difference in exhaust ports or stud locations on the 75-76 heads? |
JamesM |
May 28 2021, 05:38 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I found a machine shop owner that is willing to try removing the insert, welding the hole, and re-drilling for the stud. But he needs an exhaust to be sure the stud position is correct. Can this be done with the short 75-76 exhaust pipe section? Any difference in exhaust ports or stud locations on the 75-76 heads? If this isnt a machine shop that regularly works on type4 heads you might want to rethink that approach. Given the location of that particular stud and its proximity to the combustion chamber and valve seat they may wind up doing more harm than good. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:30 AM |
