| gereed75 |
Aug 26 2018, 07:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
These lights are the second to highest in their product line. Chose them because they are preassembled into an H4 lens and do not use a fan.
This started as a 1 hour project that as usual turned into a 4 hour thing. After fighting nearly 50 year old screws the biggest issue became where to mount the circuit board box that is part of the assembly. First impression is it should be easy, but there is really not that much room in the headlight bucket as the assembly rotates up and down and the placement is not inconsequential. Not inconsequential because one placement caught my plastic trim bucket and caused a stress crack. Bummer as these are original white ones on my '70 car. At any rate, I ended up wrap tying onto the bracket that holds the spring. This position is a good fit. and remains out of the way as the assembly moves through its motion. Pix below. Maybe this will save someone else some time (and a cracked plastic trim bucket). Warning: Many wrap ties died in the completion of this project. Oh yea, great product, low beams project a very diffuse pattern that lights a big area in front of the car. High beams are very effective. Makes night driving a whole new and safer experience. NICE!! Attached thumbnail(s) Attached image(s)
| gereed75 |
May 18 2021, 10:29 AM
I suspect they drop in to “standard” H4’s. Do not think Vintagecarleds has special H4’s made just for them, but...
Just ask them, they are domestic and responsive Not sure about the oncoming driver issue, I can only tell you that the low beam cutoff is very distinct and when projected on a wall is very low and very distinct. |
| DC_neun_vierzehn |
Jun 1 2021, 10:11 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 640 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I suspect they drop in to “standard” H4’s. Do not think Vintagecarleds has special H4’s made just for them, but... Just ask them, they are domestic and responsive Not sure about the oncoming driver issue, I can only tell you that the low beam cutoff is very distinct and when projected on a wall is very low and very distinct. I shot them a message. Will share their response. |
gereed75 LED headlight bulb install Aug 26 2018, 07:11 PM
Cairo94507 I just received a set of these lights. I will tac... May 13 2021, 12:11 PM
JeffBowlsby Any issues with your hi/lo beam selector relay aft... May 13 2021, 12:16 PM
Cairo94507 Hi Jeff,
I actually plugged mine in just to test ... May 13 2021, 12:41 PM
horizontally-opposed
…one placement caught my plastic trim bucket an... May 13 2021, 12:44 PM
Montreal914
Eventually, I found these
For $29, curios... May 16 2021, 07:18 PM
Cairo94507 OK, so I tacked this today after reviewing @geree... May 16 2021, 03:57 PM
dr.tim Nice!
I've been looking for a good 5.75... May 16 2021, 04:17 PM
OK, so I tacked this today after reviewing [b]@[... May 16 2021, 06:25 PM
Cairo94507 @horizontally-opposed Thanks for the compliments.... May 16 2021, 09:35 PM
gereed75 Looking good mike. Glad to hear that the location... May 17 2021, 06:42 AM
Cairo94507 @horizontally-opposed So I got a chance to drive... May 17 2021, 05:52 PM
[b]@[url=http://www.914world.com/bbs2/index.php?s... May 17 2021, 09:02 PM
Cairo94507 The jury may be out for quite some time on that is... May 17 2021, 09:05 PM
DC_neun_vierzehn Thanks for sharing this info.
I'm curious ...... May 17 2021, 09:25 PM
anderssj
I'm curious ..... May 18 2021, 09:51 AM
DC_neun_vierzehn
I'm curious ..... Jun 2 2021, 04:48 PM
Cairo94507 @DC_nuen_vierzehn I am not sure but the H4 headlig... May 18 2021, 06:56 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:38 PM |
