My latest challenge. Here we go again., 72 restoration and conversion to a Subaru EZ30R engine. |
rmarx |
Apr 3 2021, 11:09 PM
Member Group: Members Posts: 95 Joined: 5-June 07 From: Pleasant Hill, CA Member No.: 7,784 |
It had been about eleven years since my last 914 build. It was shown on the cover of the January 2010 Retro Cars Magazine. It was a 72 with a 327 Chev small block, GT flares , 5 lug conversion and a long list of modifications. I have spent the last eleven years building , restoring , highly modifying two separate 912s. One was converted from a short to long wheelbase RSR, the other was a 69 912 converted to an R Gruppe style 911. I have owned about eight 914s over the years and I always seem to be drawn back to their mid-engined targa topped allure.
About a year and a half ago, I obtained a 72 roller from fellow 914 world enthusiast Brian Adkins. He was nice enough to give me a good dal on the car, so it was time to begin my next crazy idea. I am installing a 2004 Subaru EZ30R engine with an 04 WRX transmission converted from four to two wheel drive. The trans is very strong and able to handle all the power I want to throw at it. It will have a hydraulic clutch and operated by a Cable system. The engine will be operated with an ECU Master computer. The power output should be in the 280-300 hp range per the experts that use these motors in sand rail conversions. The car initially received a 1.7 four generously donated by Chris Baker (Tyga Boy). I got the car running well enough to participate in last year's West Coast Rally. I actually won an award for Best Patina ( Best Shit Box) . I have since pulled the motor and trans, stripped the paint, collected most of the parts needed for the conversion and will install the new drivetrain very soon. It is my intention to show many pictures and details of the process. Many thanks to to all those that have in the past and in the future helped me to achieve my goals for this project. I couldn't do it without hem. |
rmarx |
Jun 1 2021, 11:26 AM
A little progress being made on the installation of the complete shifting mechanism. I installed the Coldwater 914 shift linkage to the transmission. I then installed the shift cables, (also supplied by Coldwater 914) and ran them though the hole that was once occupied by the shifting rod, ( let's refrain from the obvious jokes that will surely follow from that last statement). In order to connect the Heim joints on the cable to the shifter, I purchased some bronze bushings from Ace hardware that just happened to have an OD of 3/8" and an ID of 1/4". I placed a washer over the bushing to give it more clearance so that the Joint would not bind and hit metal during operation.
It was then that I decided to build a stand for the shifter to be mounted on. The whole idea was to locate the shifter higher and closer to me so that I would not have to reach so far to shift from gear to gear, as in a stock 914. Being a weekend with most metal stores closed, I had to come up with a solution that I could do on a Sunday. So I went to Ace Hardware and bought some 1" aluminum angle and 1" square tubing and began to construct a box that the shifter could be mounted on. It is held together with 6mm Allen head screws and Nut-Certed where needed. I am happy to report that this thing has all five gears along with reverse. It shifts like a Miata with a short shift kit installed. I have never felt a shifter that is this short, precise and crisp. I can't wait to see how it feels while driving. Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 06:28 PM |
