Should I part-out my 914?, advice |
dkos |
Dec 31 2004, 12:04 PM
say, "RUST"! Group: Members Posts: 295 Joined: 1-December 04 From: Philadelphia, PA Member No.: 3,204 Region Association: None |
I just happened to have a few bucks in my pocket when I came across this '72 1.7. I've always want one and figured it would be a good father/son project. Well being a bonehead with a bonus check in his pocket I bought the car (this is why my wife usually handles the money). Once I got it home and up on jacks I started to discover a lot of rust hidden under those brand new rocker panels. When I jack the car under the jack points I can see the the door frame opening up. While the battery tray looks pretty good from above, once I got under the car I discovered there was some damage to the area underneath it. The jacking donut on the passenger side rear is pretty much gone. The car runs great. It starts right up even in the cold after sitting a week. The interior looks pretty nice except for a questionable reupolstering job on the drivers seat by the PO.
I'm not afraid of hard work and I know someone willing to give me welding lessons. I'm not looking to race this car or to restore it to original form. I just want to drive it safely. Will installing the Brad Mayeurs kit make this car safe to drive? Is it worth fixing or should I try to recoup my money parting it out? Can I make my money back parting it out? Can I find a rust free 914, in the Philadelphia area, for under $5000 to replace it? Any advice appreciated. |
GWN7 |
Dec 31 2004, 12:44 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
Hello and welcome
It all depends on how much you need to repair and if you have a place to do the repairs. Skills can be learned/ tools bought. There are several members here that are doing exactly what you are describing now. Some are doing more. Post some pictures of the areas on your car and we will have a better idea of what your up against and can advise you. Take a look at the repair threads that others are doing, like THIS one for instance. There are two strengthing kits available for the car. One goes outside (Brad Mayeurs) and the other goes inside (Engman) but before you add those you should fix the cause of weakness by replacing the rusted metal and treat the other areas that can be reached with a rust inhibitor. It sounds like a doable project (car starts and runs and the rest looks ok) The satisfaction you will get when your compleated will be worth it. As long as you don't sucume to either DW or NW disease along the way. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:22 AM |
