| AZBanks |
Jun 1 2021, 09:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region
I've created a few threads with vague titles but I'm hoping the title of this thread is pretty clear.
There are places in Arizona where the summers are pretty nice. Those are the places up in the higher elevations of Arizona. I don't live in one of those places. I live in Phoenix. As you may have heard, Phoenix is hot in the summertime. Driving a car without AC in Phoenix in the summer time is pretty miserable. Car dealers don't sell cars without AC in Arizona. Satan keeps a winter home here because the summer are too hot. OTOH, it's a dry heat and I never have to shovel it. The NARP is a 71 914 that started life with a 1.7 liter engine. I had a 1.8 liter engine sitting in the garage for my other 914 project and when the 1.7 got too aggressive in marking it's territory I decided to swap in the 1.8. I also swapped in an transmission I got from Oscar at the same time. The 1.8 came with a boat anchor of a York AC compressor connected with a side mount on the passenger side of the engine. I removed that almost as soon as I got it home. I picked up the 1.8 a couple years ago from Patrick Motorsports for a GREAT deal and James said it came out of a running car so I thought it was good to go... I had never looked it over as well as I could have. I've known James for several years and trusted him and I still do. I never asked or looked at the engine to see about oil leaks. It really could have had a hole in the case and it still would have been a good deal so I don't want this to sound like a complaint about James or PMS because it is not. I cleaned a LOT of crud off the 1.8, replaced the front crank seal, swapped the engine tins from the 1.7, and installed it and James was correct, it runs great. It was still dripping some oil and I wanted to add an AC system so it is back out of the car less than 500 miles since it first went in. I've tracked the oil leaks to a couple push rod tubes so all the push rod tubes are getting new seals. Another reason I dropped the engine was to replace the shift input shaft seal on the transmission. It was the only seal I didn't replace last time I had it out of the car and of course, it just had to leak. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) It didn't help that I put Swepco oil in the trans before I installed it the first time. The good(Evil) Dr. set me straight so it is now running good old 90 weight Dino oil. The transmission now has all new seals and is ready to go back in the car. The engine will have the new push rod tube seals and oil cooler seals to go with the new front crank seal I put in before the first install. So there is the background on the engine and trans. Now it's time for the AC system. This is a total experiment based on other AC threads here and on the bird and based on systems and guess-timats from other cars. I made some of my guess-timats based on parts and sizes from my 1990 944 S2 Cab. The cabin of the 94 is a bit smaller than the 944 cab so parts that can cool the 944 should be about the right size to cool the cabin of the 914. As I said, the 1.8 liter engine came to me with an OLD York compressor. I did not want to use that massive HP hog. There was a decent pulley mounted behind the fan but it is also a heavy piece of steel. I bought an original dealer installed style AC system a few years ago from some one either here or on the bird board(I don't remember which and it doesn't really matter at this point). I bought it mainly for the under-dash evaporator and the controls. The NARP never had AC so it is not hacked up. It has 99 problems but ragged holes in the body and front trunk for AC aren't any of them. The engine tin on the passenger side of the 1.8 is hacked up and bent up pretty bad. I should have taken pictures before I started cleaning it up. I am going to finish cleaning it up and paint it. I don't want to hack up the good tin that was on the 1.7. I'll save that and hack it up for my next project. (IMG:style_emoticons/default/sawzall-smiley.gif) With the advances in modern compressors, condensers, and fans I decided to try an installation with the condenser mounted to the underside of a GT style engine lid. In addition to the original style under dash evaporator, I am using a Sanden sd5h11 6333 compressor. It is the modern equivalent of the SD507 and is designed to use R-134a. I will be mounting it to the passenger side of the engine with amount plate I got from Gilmore Enterprises out of Las Vegas. Their website (gilmore-enterprises.net) doesn't list parts for the 914 or any individual parts but Ed, the owner is super easy to deal with. I called him up, told him what I was looking for, and it was on the truck heading out to me later that day. I picked a universal fit parallel flow 11" X 21" condenser and 2 high flow, low profile 10" fans and a drier with a trinary switch. |
| AZBanks |
Jun 2 2021, 09:47 PM
I'm no engineer and I didn't sleep at a Holiday Inn last night.
I'm making a bunch of highly uneducated guesses building a system in hopes it cools my car down. Is it going to be perfect??? Well, Yeah, Duh, of course it is!!! (IMG:style_emoticons/default/aktion035.gif) Ok, that's possibly not true but I'm not shooting for perfection here, just a reasonably cool car. (IMG:style_emoticons/default/ar15.gif) I agree (IMG:style_emoticons/default/agree.gif) blowing hotter air into the engine compartment and into the intake may be detrimental to the total HP my car is making. Adding the AC system is a HP drain in the first place. If HP was high on my priority list, I wouldn't be installing a used 1.8 running carbs. (IMG:style_emoticons/default/huh.gif) I'm mildly curious about Keith's electric AC system. I mean no disrespect by that. I would be a lot more curious if I hadn't already spent the money on a bunch of parts for a more traditional system. If I didn't have a bunch of parts sitting in my garage, I would be HUGELY curious about his system. I am very happy he had the creativity to build his system and that he is happy with it. I'm always happy to take advice from the 914world design committee... Except for Tygaboy, he didn't use my vent design ideas so screw him. (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) (That's a joke. Tygaboy is one of my hero's around here. If this project looks even half as good as his work when it is done, I'll call it a success) |
| bbrock |
Jun 3 2021, 06:52 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I'm always happy to take advice from the 914world design committee... Except for Tygaboy, he didn't use my vent design ideas so screw him. (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) For sure the most bitter disappointment of that project (IMG:style_emoticons/default/lol-2.gif) |
AZBanks Beat the Arizona Heat - My custom AC system build Jun 1 2021, 09:09 PM
AZBanks Working on the lid.
Jun 1 2021, 09:13 PM
AZBanks I still have a bunch of hose and a bunch of fittin... Jun 1 2021, 09:15 PM
SKL1 I guess I don't suffer quite as much in north ... Jun 1 2021, 09:57 PM
bkrantz I lived in Tucson for most of the 80s, and never h... Jun 1 2021, 10:22 PM
AZBanks I hear you about the "hack jobs". I coul... Jun 2 2021, 12:14 AM
AZBanks I will have a couple small holes in the body to ru... Jun 2 2021, 12:18 AM
ClayPerrine From experience, and from working with my father (... Jun 2 2021, 05:52 AM
AZBanks
From experience, and from working with my father ... Jun 2 2021, 09:43 AM
ClayPerrine
From experience, and from working with my father... Jun 2 2021, 10:46 AM
AZBanks
[quote name='AZBanks' post='2920312' date='Jun 2 ... Jun 2 2021, 01:05 PM
914_teener
From experience, and from working with my father ... Jun 2 2021, 10:56 AM
Warren914 @[url=http://www.914world.com/bbs2/index.php?showu... Jun 13 2021, 08:33 AM
ClayPerrine
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 13 2021, 09:52 AM
Coondog Great post... :first: Jun 2 2021, 07:43 AM
76-914 I wonder if the warm air of the condenser will aff... Jun 2 2021, 08:54 AM
AZBanks
I wonder if the warm air of the condenser will af... Jun 2 2021, 09:55 AM
slowrodent AZBanks,
Thanks much for initiating this thread. ... Jun 2 2021, 10:15 AM
slowrodent PS.. I had sized my condenser to be very similar t... Jun 2 2021, 10:16 AM
Chris914n6 Use bulkhead fittings into the cab & thru shee... Jun 2 2021, 10:36 AM
AZBanks
Use bulkhead fittings into the cab & thru she... Jun 2 2021, 11:48 AM
ClayPerrine With Betty's car, we were using the original d... Jun 2 2021, 01:24 PM
914_teener
With Betty's car, we were using the original ... Jun 2 2021, 02:14 PM
Chris914n6
With Betty's car, we were using the original ... Jun 2 2021, 07:01 PM
914_teener
With Betty's car, we were using the original... Jun 2 2021, 07:18 PM
914Toy
[quote name='Chris914n6' post='2920432' date='Jun... Jun 2 2021, 07:42 PM
914_teener
I'm no engineer and I didn't sleep at a H... Jun 3 2021, 12:22 AM
AZBanks
:beer2:
Another option is to move to Prescott... Jun 3 2021, 12:49 AM
76-914 Yes, the air flow direction is down. Those two lit... Jun 2 2021, 10:35 PM
zipedadoo Are you familiar with AAPAK? They are a big autom... Jun 3 2021, 09:41 PM
AZBanks
Are you familiar with AAPAK? They are a big auto... Jun 3 2021, 11:58 PM
type2man Did Gilmore ship you the pulley and belt too? That... Jun 7 2021, 08:33 PM
AZBanks
Did Gilmore ship you the pulley and belt too? Tha... Jun 8 2021, 07:15 PM
AZBanks RE: Beat the Arizona Heat - My custom AC system build Jun 8 2021, 09:15 PM
AZBanks Does anyone know what this is, It fell off the eng... Jun 8 2021, 09:17 PM
nditiz1 Looks like the side cover plate from a distributor... Jun 9 2021, 05:19 AM
Mark Henry @Warren914
This is do-able.
Just wish I knew be... Jun 9 2021, 07:14 AM
Warren914 Any concerns with the engine lid? Where does rain ... Jun 9 2021, 07:56 AM
ClayPerrine
Any concerns with the engine lid? Where does rain... Jun 9 2021, 08:58 AM
Warren914 What type condenser are you planning?
I've lo... Jun 9 2021, 09:56 AM
AZBanks
I've l... Jun 9 2021, 10:25 AM
Shivers This may become a must do for me. I don't tole... Jun 9 2021, 10:40 AM
AZBanks Making progress.
Jun 15 2021, 05:44 PM
AZBanks Grillin' time!
AZBanks Testing the mount.
Jun 15 2021, 05:46 PM
AZBanks There is a lot more metal missing than I would lik... Jun 15 2021, 05:49 PM
AZBanks After media blasting and a coat of primer.
Jun 15 2021, 05:50 PM
AZBanks Put a lid on it!
Jun 15 2021, 05:52 PM
AZBanks Getting close.
I just need some additional spacer... Jun 15 2021, 05:58 PM
Warren914 I really like what you're doing and have high ... Jun 15 2021, 06:26 PM
Mark Henry Cool watching someone else do it before I have a g... Jun 15 2021, 07:16 PM
AZBanks
Cool watching someone else do it before I have a ... Jun 16 2021, 04:52 PM
djway The compressor mount can be modified for the compr... Jun 15 2021, 11:48 PM
76-914 Thinking out loud here but I'm wondering about... Jun 16 2021, 06:30 PM
914forme Kent, fans are always better at pulling air, than ... Jun 16 2021, 08:41 PM
76-914
Kent, fans are always better at pulling air, than... Jun 17 2021, 02:01 PM
914Toy I share Kent’s point. AC needs plenty of efficie... Jun 16 2021, 09:09 PM
AZBanks
I share Kent’s point. AC needs plenty of effici... Jun 17 2021, 01:42 PM
Chris914n6
I share Kent’s point. AC needs plenty of effic... Jun 17 2021, 04:34 PM
914e @azbanks This might help you avoid drilling holes... Jun 17 2021, 08:56 PM
Mark Henry
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 18 2021, 09:08 AM
AZBanks This is the wiring diagram and info I am working f... Jun 18 2021, 05:48 PM
Chris914n6
This is the wiring diagram and info I am working ... Jun 18 2021, 08:49 PM
michael7810
This is the wiring diagram and info I am working ... Jun 18 2021, 10:05 PM
AZBanks I have space to go up to a 12" X 26" con... Jun 21 2021, 11:51 AM
AZBanks Side view.
I had to add the 1" square alumin... Jun 21 2021, 11:56 AM
AZBanks I was very worried about the compressor hitting th... Jun 21 2021, 11:59 AM
AZBanks Here is the lid closed with all hoses connected.
... Jun 21 2021, 12:02 PM
AZBanks Here is the lid open with the hoses routed.
The bi... Jun 21 2021, 12:09 PM
AZBanks Here is the compressor with the lines connected. I... Jun 21 2021, 12:13 PM
djway I wish you cool wind Jun 21 2021, 09:42 PM
Warren914 I've ordered a 12x24 condenser from Vintage Ai... Jun 22 2021, 06:10 AM
Warren914 This looks useful. I'll be reading through to ... Jun 22 2021, 07:16 AM
Warren914 Have you had the system running yet?
How is it pe... Jul 21 2021, 06:32 PM
Warren914 How did you route refrigerant lines from the engin... Oct 4 2021, 07:10 AM
76-914 Assuming you've completed the install, how did... May 12 2022, 09:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:06 PM |
