> Eyebrow grommet installation, Ended up using 030 mig wire
john77
post Jun 2 2021, 03:36 PM
I just ordered a set of 914rubber eyebrow grommets... is there a trick or tool for installing these things without a) piercing them with a screwdriver, or b) screaming words that young children shouldn't hear?
Also, how on earth do you get enough leverage to install the one that's inside the fender?
windforfun
post Jun 3 2021, 04:30 PM
What are the eyebrow grommets for?
john77
post Jun 3 2021, 05:06 PM
They attach the eyebrows to the car - two through the trunk, one through the fender. They're the only thing holding them in place, so if you lose a bung, you may lose an eyebrow on the freeway (ask me how I know... ).
QUOTE(windforfun @ Jun 3 2021, 03:30 PM) *
ClayPerrine
post Jun 4 2021, 05:59 AM
QUOTE(john77 @ Jun 3 2021, 06:06 PM) *
Been there, done that. Hit a bump on 114 north of DFW airport and saw a red flash go past the driver's window. With all the truck traffic on that road, I didn't bother to go back and try to find it.
I just pulled another out of my parts stash and sent them both to the body shop to get the replacement painted. He needed the other one for a color sample.
When they come back, I will be putting a screw in one end to make sure they don't go flying again.
Clay
john77   Eyebrow grommet installation   Jun 2 2021, 03:36 PM
roblav1   Palmolive. Marge, you're soaking in it! F...   Jun 2 2021, 03:46 PM
john77   @[url=http://www.914world.com/bbs2/index.php?showu...   Jun 3 2021, 01:42 PM
bbrock   "Sorry, swearing is mandatory but piercing ...   Jun 3 2021, 01:47 PM
john77   Right? It never would have dawned on me, but I can...   Jun 3 2021, 01:50 PM
bbrock   Sorry, swearing is mandatory but piercing is not. ...   Jun 2 2021, 04:53 PM
bdstone914   Wrap some dental floss in the groove of the gromet...   Jun 2 2021, 04:57 PM
Al Meredith   K-Y is the slickest   Jun 3 2021, 03:40 PM
windforfun   What are the eyebrow grommets for?   Jun 3 2021, 04:30 PM
john77   They attach the eyebrows to the car - two through ...   Jun 3 2021, 05:06 PM
ClayPerrine   They attach the eyebrows to the car - two through...   Jun 4 2021, 05:59 AM
partwerks   I warmed the rubber up a bit with a heat gun to ma...   Jun 3 2021, 05:57 PM
windforfun   Stupid question here - what's an eyebrow? :h...   Jun 3 2021, 06:04 PM
bbrock   Stupid question here - what's an eyebrow? :...   Jun 3 2021, 06:41 PM
Mikey914   The metal plate between the eye (headlight) and th...   Jun 3 2021, 06:09 PM
PanelBilly   Always use the water based lube. The silicone stuf...   Jun 3 2021, 07:28 PM
ejm   The factory designed the grommets to be installed ...   Jun 4 2021, 05:53 AM
914e   The factory designed the grommets to be installed...   Jun 4 2021, 09:47 AM
Root_Werks   A few have already pointed out the obvious: Reason...   Jun 4 2021, 11:26 AM
john77   Wow, who knew there was so much I didn’t know ab...   Jun 5 2021, 10:44 AM
- Lo-Fi Version Time is now: 23rd October 2026 - 06:48 PM
