Headlight switch removal |
partwerks |
Jun 12 2021, 07:45 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
To remove the pull part on the headlight switch, after turning the coin shaped piece loose from the dash face, is there some sort of set screw to remove it? |
bkrantz |
Jun 12 2021, 07:58 PM
914 Guru Group: Members Posts: 7,791 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
To remove the pull part on the headlight switch, after turning the coin shaped piece loose from the dash face, is there some sort of set screw to remove it? No. After unscrewing the knob, and the shaft retaining nut (shiny round thing with the notches), the switch should pull out from behind the dash. The wire harness may be stiff. |
partwerks |
Jun 12 2021, 08:10 PM
To remove the pull part on the headlight switch, after turning the coin shaped piece loose from the dash face, is there some sort of set screw to remove it? No. After unscrewing the knob, and the shaft retaining nut (shiny round thing with the notches), the switch should pull out from behind the dash. The wire harness may be stiff. So at this point, I just need to unscrew it, it sounds like? |
Lo-Fi Version | Time is now: 1st June 2024 - 08:00 AM |
