| BeatNavy |
Apr 6 2021, 08:51 AM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
I'm inching closer, ever closer at a glacial pace, to break down and learn how to paint. I'm probably going to buy a turbine HLVP setup soon. I think I've finally decided to take my car back to its original L60E, Irish Green.
Question: why can't I find a place that will mix this? I initially tried places in Maryland until I learned that one really can't buy anything other than water-based paint in Maryland. Ok, so I'm willing to drive to Delaware or Virginia. But I've called like 6 places, and while they can find L60E in their book, they don't seem to be able to mix it. I do have a place about and hour and a half away from me in VA that says he "probably" can mix it up. I'd like a little more confidence than "probably" before I take a 3 hour round trip. Totally new to this process, so I'm looking for ideas. |
| BeatNavy |
Apr 7 2021, 05:40 PM
Just pulled the trigger on one of these. It's not cheap, but I'm looking forward to seeing how well it masks a newbie's lack of skill and knowledge. Some people suggest you can do a great job with the model below this, but I think Fuji recommends this one (or higher) for full car painting. I'll share my experiences.
| john77 |
Jun 14 2021, 06:46 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California
@BeatNavy I've been considering turbines for when I paint my car. From my research Fuji say you want a 4 stage or 5 stage for automotive paint, so it looks like you're on the right track.
I follow this painter on youtube and he seemed pretty impressed with the Fuji model above that one: https://www.youtube.com/watch?v=GWcDgILe13k I was about to pull the trigger on a Q5 so I'm really interested to see how this works out for you. Just pulled the trigger on one of these. It's not cheap, but I'm looking forward to seeing how well it masks a newbie's lack of skill and knowledge. Some people suggest you can do a great job with the model below this, but I think Fuji recommends this one (or higher) for full car painting. I'll share my experiences. |
| BeatNavy |
Jun 15 2021, 06:56 AM
@BeatNavy I've been considering turbines for when I paint my car. From my research Fuji say you want a 4 stage or 5 stage for automotive paint, so it looks like you're on the right track. I follow this painter on youtube and he seemed pretty impressed with the Fuji model above that one: https://www.youtube.com/watch?v=GWcDgILe13k I was about to pull the trigger on a Q5 so I'm really interested to see how this works out for you. Hey @john77 and all. Sorry, I should have posted an update, but I'm really bad about that. I'm also really bad about taking the time to take good pictures to document process and progress. So I ended up buying that Fuji mini mite 4 platinum as shown in the pic. It was super easy to setup, and, when the time came, to clean. I also did pickup some L60E from the place in New Castle, DE. Guy was very friendly and helpful, and I'll go back up there when I need paint to do the whole car. This time I was just respraying/practicing on the roll bar and sail panels, which were going to be covered with new vinyl anyway. My overall thoughts and impressions: I'm very happy with the turbine setup. Again, it's so easy to setup, it's portable, uses 110v, is relatively quiet, there's very little overspray, and I think it can do an excellent job. Cleaning was also very straightforward. I managed to laydown some pretty nice sections of paint, but my lack of experience (both overall and with this system) definitely led to some "opportunities for improvement" as my boss might say. First thing I noticed was that I didn't get the paint thick enough initially. The guy at the store told me to mix it 4 to 1 (paint and reducer), which I did. I also told him I need a slow-drying reducer, which is what is recommended for turbine sprayers. The paint ended up too thin and I ended up with runs on the sail panel. The next time I actually used the Ford #4 cup that comes with the sprayer to test viscosity, and that's when I realized I needed significantly less reducer. Mistake #1. Mistake #2 was initially trying to correct the runs by reducing airflow, which I now understand is the last adjustment that should be used. You want airflow for complete atomization of paint. I should have been a) using correct viscosity/mixture as noted above, and b) using paint flow adjustment before air flow adjustment. You can see some orange peel in the pics below, particularly on sail panel. Mistake #3 (and 4, and 5, and 6, etc., etc.) was simply technique. I practiced on some sheet metal I had. Naturally some of the best paint I laid down is now on that scrap sheet metal (IMG:style_emoticons/default/smile.gif) I found painting the rollbar a challenge as it's hard to reach over and get a consistent angle of attack and motion on something that goes across the whole car. The sail panels were easier, naturally, but then I was dealing with the fact that I bollocksed them up the first time with too thin of paint and had to clean off the runs with solvent. That left a surface that was less than ideal for the second attempt. After a bunch of sanding and attempts at paint correction I was pretty happy with the overall results in the sense that I learned quite a bit, it looks much better than it did, and the new sail panel vinyl looks great and covers up my mistakes anyway (IMG:style_emoticons/default/biggrin.gif) Bottom line: I like this setup a LOT and I'm looking forward to trying again. It just won't happen until I'm ready to tackle the whole enchilada. Here are some random pics of the pain on the car, just for viewing pleasure. Again, not even sure what order these are in from raw paint to post-paint correction attempt. |
| john77 |
Jun 15 2021, 01:19 PM
@BeatNavy Looks great... i mean, you can always sand the orange peel out of the clear anyway, right? (IMG:style_emoticons/default/biggrin.gif)
What size air cap did you use? It seems like they come with a 1.3mm, which is fine for primer, but the 1mm or 0.8 is better for base/clear? @BeatNavy I've been considering turbines for when I paint my car. From my research Fuji say you want a 4 stage or 5 stage for automotive paint, so it looks like you're on the right track. I follow this painter on youtube and he seemed pretty impressed with the Fuji model above that one: https://www.youtube.com/watch?v=GWcDgILe13k I was about to pull the trigger on a Q5 so I'm really interested to see how this works out for you. Hey @john77 and all. Sorry, I should have posted an update, but I'm really bad about that. I'm also really bad about taking the time to take good pictures to document process and progress. So I ended up buying that Fuji mini mite 4 platinum as shown in the pic. It was super easy to setup, and, when the time came, to clean. I also did pickup some L60E from the place in New Castle, DE. Guy was very friendly and helpful, and I'll go back up there when I need paint to do the whole car. This time I was just respraying/practicing on the roll bar and sail panels, which were going to be covered with new vinyl anyway. My overall thoughts and impressions: I'm very happy with the turbine setup. Again, it's so easy to setup, it's portable, uses 110v, is relatively quiet, there's very little overspray, and I think it can do an excellent job. Cleaning was also very straightforward. I managed to laydown some pretty nice sections of paint, but my lack of experience (both overall and with this system) definitely led to some "opportunities for improvement" as my boss might say. First thing I noticed was that I didn't get the paint thick enough initially. The guy at the store told me to mix it 4 to 1 (paint and reducer), which I did. I also told him I need a slow-drying reducer, which is what is recommended for turbine sprayers. The paint ended up too thin and I ended up with runs on the sail panel. The next time I actually used the Ford #4 cup that comes with the sprayer to test viscosity, and that's when I realized I needed significantly less reducer. Mistake #1. Mistake #2 was initially trying to correct the runs by reducing airflow, which I now understand is the last adjustment that should be used. You want airflow for complete atomization of paint. I should have been a) using correct viscosity/mixture as noted above, and b) using paint flow adjustment before air flow adjustment. You can see some orange peel in the pics below, particularly on sail panel. Mistake #3 (and 4, and 5, and 6, etc., etc.) was simply technique. I practiced on some sheet metal I had. Naturally some of the best paint I laid down is now on that scrap sheet metal (IMG:style_emoticons/default/smile.gif) I found painting the rollbar a challenge as it's hard to reach over and get a consistent angle of attack and motion on something that goes across the whole car. The sail panels were easier, naturally, but then I was dealing with the fact that I bollocksed them up the first time with too thin of paint and had to clean off the runs with solvent. That left a surface that was less than ideal for the second attempt. After a bunch of sanding and attempts at paint correction I was pretty happy with the overall results in the sense that I learned quite a bit, it looks much better than it did, and the new sail panel vinyl looks great and covers up my mistakes anyway (IMG:style_emoticons/default/biggrin.gif) Bottom line: I like this setup a LOT and I'm looking forward to trying again. It just won't happen until I'm ready to tackle the whole enchilada. Here are some random pics of the pain on the car, just for viewing pleasure. Again, not even sure what order these are in from raw paint to post-paint correction attempt. |
BeatNavy Where to Source Paint Apr 6 2021, 08:51 AM
jd74914 There is a PPG dealer nearby who can mix paint wit... Apr 6 2021, 08:56 AM
Mikey914 True L60E probably has some items in it that you c... Apr 6 2021, 09:02 AM
Shivers I don't know if this will help but:
"1970... Apr 6 2021, 09:11 AM
jasons When I painted my car, I went to one of the best p... Apr 6 2021, 09:19 AM
roblav1 The PPG dealer in Suffolk, VA mixed my paint. I g... Apr 6 2021, 09:44 AM
roblav1 Also, the Black Widow HVLP gun from Harbor Freight... Apr 6 2021, 09:45 AM
BeatNavy Thanks for the suggestions. I did call the nation... Apr 6 2021, 10:01 AM
BeatNavy I called a couple of other shops in MD and VA toda... Apr 6 2021, 03:19 PM
914e
I called a couple of other shops in MD and VA tod... Apr 6 2021, 03:32 PM
roblav1 When I was in the PPG store in Suffolk, they showe... Apr 6 2021, 04:05 PM
BeatNavy Thanks, @914e and [b]@[url=http://www.914world.... Apr 6 2021, 04:21 PM
76-914 My only experience with a Turbine HVLP was about 2... Apr 6 2021, 04:23 PM
BeatNavy
My only experience with a Turbine HVLP was about ... Apr 6 2021, 04:36 PM
rudedude I just painted a 911 using a turbine and was quite... Apr 6 2021, 07:37 PM
mepstein Rob - Call me if I can help with any DE shops. We ... Apr 6 2021, 07:49 PM
wndsrfr Best paint I ever got was Glasurit...15 years ago ... Apr 6 2021, 07:57 PM
BeatNavy Thanks, Mark / John. Mark, I called two of the Ka... Apr 7 2021, 05:53 AM
mepstein When you think you found the right paint, buy a sm... Apr 7 2021, 07:28 AM
BeatNavy
When you think you found the right paint, buy a s... Apr 7 2021, 07:36 AM
BeatNavy @wndsrfr from the BASF website you posted I found... Apr 7 2021, 07:28 AM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Apr 7 2021, 07:38 AM
BeatNavy Thanks, Mark, I appreciate the offer. I'll le... Apr 7 2021, 07:44 AM
bbrock I can't offer anything new here but will share... Apr 7 2021, 07:55 AM
StarBear
I can't offer anything new here but will shar... Apr 7 2021, 12:21 PM
BillJ
I can't offer anything new here but will shar... Apr 8 2021, 05:59 AM
bbrock
Did you happen to save the formulas that they pro... Apr 8 2021, 07:42 AM
BillJ
Did you happen to save the formulas that they pr... Apr 8 2021, 01:43 PM
mgarrison I found Ravenna Green at this site:
https://www.a... Apr 7 2021, 09:56 AM
BillC I've been getting the paint for the dapo-speci... Apr 7 2021, 11:46 AM
930cabman Our 356SC is factory Irish Green and has been spot... Apr 7 2021, 12:24 PM
worn I have had good luck with PPG paint. Expensive st... Apr 7 2021, 04:40 PM
worn
Just pulled the trigger on one of these. It... Apr 7 2021, 06:06 PM
jd74914
Just pulled the trigger on one of these. It... Apr 8 2021, 07:25 AM
BeatNavy
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 15 2021, 02:01 PM
Freezin 914 :popcorn: Apr 7 2021, 06:20 PM
930cabman Is anyone making the original synthol enamel singl... Jun 14 2021, 03:37 PM
Superhawk996 Orange peel is free all day long if you want it. ... Jun 14 2021, 03:57 PM
windforfun Try paintscratch.com. They matched my marathon bl... Jun 14 2021, 04:56 PM
Front yard mechanic Try TPC global / auto color library. mfg. code 6... Jun 14 2021, 09:09 PM
rjames Wahoo!
:Qarl: :headbanger: Jun 15 2021, 01:41 PM
930cabman Is anyone using single stage? as opposed to base/c... Jun 15 2021, 04:20 PM
crash914 Try Marty's auto paint in Baltimore/Rosedale.
... Jun 17 2021, 03:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:48 PM |
