> Oil leaks after rebuild, Dropping motor to track down oil leaks
Wew
post Apr 28 2021, 09:49 AM
Hi all,
Engine rebuild has not gone as smooth as I had hoped.
I am dropping the engine again to figure out the source of my leaks.
I have drips coming from a couple of the tube on the passenger side under the oil cooler.
Tough to tell if it's the cooler or the tubes.
Cylinder 3 is giving me the most concern.
It almost looks like one of the four cylinder studs is leaking oil.
I can't tell exactly as it could be the actual mating surface of the cylinder and the block.
Anyway I am dropping the motor to track these down.
Has anyone else come across oil leaking out of a stud or is this just the cylinder and engine mating surface leaking?
If it is how have any of you remedied this?
Is there a bullet proof sealant that others have used to stop this?
Attached is an image I borrowed online that shows the location of where I see oil coming from.
Thanks for sharing as always.
Wew
post Jun 16 2021, 12:27 PM
Hi all,
I am back at putting my engine back together. Thanks Mark Henry and Rich from 914 werke and all the others for being so helpful with advice and recommendations.
I purchased the oil pressure kit with the brake line adapter to avoid damaging the threaded opening in the case. Loctite thread sealer all the way around the threads throughout the extension and the pressure sender.
Fingers crossed.
I also purchased the oil cooler for the 914 2.0. Learn from my mistakes and do not buy an oil cooler from your local vw aircooled shop, although a close fit, it doesn't fit right and you have to do some grinding and macgyvering to make it fit right. A recipe for leaks, ask me how I know.
Also, when you have your local air cooled shop do your rocker balancing double check their work. I should have sucked it up and done it myself. Would have done a better job in hindsight. #3 exhaust was so loose that you could have stuck a 2x4 between it for the gap. Not impressed with their quality of work to say the least. Nothing was set at zero lash as I had requested.
Now I am moving on to other pieces for assembly and am having a heck of a time getting the SSI to line up with the exhaust studs. Three came out of the heads when originally loosening. I had to reset the and tighten them up. Now as a by product of that I cannot get the exhaust opening and the SSI exhaust to line up the way I would like.
The only thing I can think of is loosening the studs again then sliding the SSI's back over them and then tighten the studs prior to tightening the actual copper nut.
I also had a tough time getting the banana muffler to line up with the exhaust and had to use a strap to pull them a little closer together to line up with the muffler.
Even after cranking down on the exhaust and muffler bolts it still seemed like they did not meet flush even with the proper gaskets.
Interested to hear what others have done in these situations.
Thanks again and getting closer to another install and test.
Wew   Oil leaks after rebuild   Apr 28 2021, 09:49 AM
Wew   Are the 1973 2.0 engines supposed to have the push...   Apr 28 2021, 12:48 PM
Mark Henry   Where's the underside cooling tin? What did y...   Apr 28 2021, 02:27 PM
wonkipop   Where's the underside cooling tin? What did ...   May 15 2021, 02:04 AM
Mark Henry   Where's the underside cooling tin? What did...   May 15 2021, 05:09 AM
wonkipop   [quote name='wonkipop' post='2915960' date='May 1...   May 15 2021, 09:52 PM
Wew   Hi Mark, I removed the tin to see the leaks. I u...   Apr 28 2021, 03:08 PM
76-914   Don't overlook the oil pressure sender or more...   Apr 28 2021, 04:14 PM
Wew   sage advice... Will check there as well. I hate o...   Apr 28 2021, 04:37 PM
Mark Henry   So you took the pushrod tubes out to remove the ti...   Apr 28 2021, 04:42 PM
Wew   ahh... That is a photo I borrowed from another us...   Apr 28 2021, 04:46 PM
Mark Henry   Okay as long as you have those tins, your engine a...   Apr 28 2021, 06:32 PM
Wew   Dropped the engine tonight. That’s about all I c...   Apr 28 2021, 08:03 PM
iankarr   Four of the cylinder head bolts/studs pass through...   Apr 28 2021, 08:16 PM
Wew   Thanks for softening the blow Ian. Mark, I could...   Apr 28 2021, 09:25 PM
Mark Henry   Looks like the PR tube at the head, then it's ...   Apr 30 2021, 06:42 AM
Wew   Thanks Mark. I removed the fan housing shroud. ...   May 1 2021, 10:40 AM
Wew   Two examples of the set up from PO. Consideri...   May 2 2021, 12:24 PM
Mark Henry   I personally would use a whip. That fitting and a ...   May 2 2021, 12:54 PM
FlacaProductions   If you want to keep the gauge, you may want to re-...   May 2 2021, 12:58 PM
Wew   That great info from both of you. I got a better ...   May 2 2021, 10:22 PM
76-914   So it was OP sender.That looks like it is chipped ...   May 3 2021, 08:15 AM
Wew   Yikes, Not what I wanted to hear. Can this be d...   May 3 2021, 11:28 AM
Wew   What are you thoughts on putting the sensor flush ...   May 4 2021, 12:43 PM
Root_Werks   Isn't there another galley you can unplug and ...   May 4 2021, 01:56 PM
Shivers   Before I gave up and started tearing it down. I...   May 4 2021, 02:43 PM
Wew   Two good points. I have an appointment with a sho...   May 5 2021, 09:18 AM
Root_Werks   I would like to know the outcome of this leak. Ha...   May 5 2021, 09:54 AM
Mark Henry   Wew are you sure it's leaking from the switch?...   May 15 2021, 05:19 AM
Superhawk996   Been there, done that with leaking oil pressure sw...   May 15 2021, 08:48 AM
barefoot   When i got my 911SC it had an oil leak I couldn...   May 16 2021, 06:05 AM
Wew   Hi all, Sorry for the absence. Been away on vaca...   May 17 2021, 02:32 PM
Wew   Hi all, I am back at putting my engine back toget...   Jun 16 2021, 12:27 PM
ClayPerrine   I also had a tough time getting the banana muffl...   Jun 16 2021, 12:51 PM
Wew   Hi all, Engine back in and running better after v...   Jun 29 2021, 07:38 PM
Wew   I just looked at some torque specs for the oil pre...   Jun 29 2021, 10:42 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:41 PM
