> Getting All Gears Except 4th in my 74, Shift linkage adjustment for side shifter
munkmunk
post Jun 16 2021, 12:27 PM
I recently removed my rear shifter bar from my stock 74 to take a close look at all the shift bushings and the set screws. All looked good, but I replaced the the bushing at the gearbox and both of conical set screws anyway.
While separating the shift coupler from the front shift bar (the one in the tunnel) I THINK the position of the front bar changed inside the clamp at the base of the shift lever. So I had my wife hold the shift lever in the neutral position with it tilted fully over to the right. Then I loosened the 13mm bolt at the clamp just behind the shift lever. Then I crawled under the car and rotated the rear bar fully clockwise until it stopped. Wife then tightened the 13mm bolt on the clamp.
Took it for a drive and I get R, 1st, 2nd, 3rd and 5th. But when I try to go for 4th, it feels like the lever hits something solid. There's no engagement at all into 4th. I CAN get 5th. Any ideas? Before I checked my bushings, I was able to get all the gears fine.
ClayPerrine
post Jun 16 2021, 12:33 PM
Here are some directions on how to adjust the side shifter.
http://www.914world.com/bbs2/index.php?sho...shifter++bungee
I hope it helps.
Clay
- Lo-Fi Version Time is now: 17th July 2025 - 05:05 AM
