Adjusting Air / Fuel Mixture |
sjhenry1075 |
Jun 22 2021, 08:29 AM
Member Group: Members Posts: 268 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
Hey everyone, please excuse my lack of knowledge on this subject, but I have a question regarding air / fuel mixture adjustment on my 71 1.7 with stock D-jet. I posted this question on Facebook but wanted to try here as well.
Back story: my car will only idle and drive when both vacuum lines are disconnected from the distributor. When connected (I used a diagram found on 914world so I know they aren't flipped) the car barely idles when cold or warm, and it is almost undriveable; it surges, bucks, and hesitates. If I remove both vacuum lines from the distributor it idles and runs great. From what I understand from the replies on FaceBook, this could be an air/fuel mixture issue, but how is that adjusted with for the 71? Is there a certain procedure for this? Thanks in Advance for any assistance you can provide! For those going to PA for the Northeast gathering, I'm looking forward to meeting you! |
brant |
Jun 22 2021, 01:03 PM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
another thing that can make the car run rich is a failing Cylinder Head Temp sensor
you can check them with an OHM meter. pulling if from the engine isn't hard.. involves a modified 13mm deep socket. and allows you to put the sensor into the freezer or boiling water for the full range testing. |
sjhenry1075 |
Jun 22 2021, 04:49 PM
another thing that can make the car run rich is a failing Cylinder Head Temp sensor you can check them with an OHM meter. pulling if from the engine isn't hard.. involves a modified 13mm deep socket. and allows you to put the sensor into the freezer or boiling water for the full range testing. When cold, how many OHMs should be showing? I thought it may be this that is causing the issue. |
rjames |
Jun 22 2021, 05:38 PM
I'm made of metal Group: Members Posts: 3,954 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
another thing that can make the car run rich is a failing Cylinder Head Temp sensor you can check them with an OHM meter. pulling if from the engine isn't hard.. involves a modified 13mm deep socket. and allows you to put the sensor into the freezer or boiling water for the full range testing. When cold, how many OHMs should be showing? I thought it may be this that is causing the issue. If you can keep your car running long enough to get the engine warmed up you don't have to remove the CHT to test resistance. Just unplug it before measuring. When the engine is cold it should read ~ 2.8-3 K ohms. After engine is fully warmed up it should read ~ 191-199 ohms. Just about all of the FI troubleshooting info you could want can be found here: https://members.rennlist.com/pbanders/DJetParts.htm |
Lo-Fi Version | Time is now: 7th June 2024 - 01:44 PM |
