sound deadening, engine compartment pad |
dlindzey |
Apr 25 2021, 08:49 AM
repeat offender Group: Members Posts: 33 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region |
there are at least two different versions on the usual parts sites-
aase $200 pelican $125 AA $200 any practical experience or obvious best choice in taking care of this need? |
Mikey914 |
Jun 27 2021, 03:39 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just to speak to the construction on the 914Rubber.com pad.
We use an OEM style felt pad that is treating to make it more water resistant. Instead of using a tar, we use a rubber that will work to absorb sound, is more fire resistant and is MUCH lighter than the OEM pads. Once installed it looks pretty stock. Our cost on these will be going up shortly due to materials cost should be about $20 but until we sell the product we were able to make at the lower cost you save. |
digit3 |
Jun 27 2021, 04:34 PM
Newbie Group: Members Posts: 29 Joined: 23-November 19 From: Tucson Member No.: 23,665 Region Association: Southwest Region |
Just to speak to the construction on the 914Rubber.com pad. We use an OEM style felt pad that is treating to make it more water resistant. Instead of using a tar, we use a rubber that will work to absorb sound, is more fire resistant and is MUCH lighter than the OEM pads. Once installed it looks pretty stock. Our cost on these will be going up shortly due to materials cost should be about $20 but until we sell the product we were able to make at the lower cost you save. I don't care too much about stock look. Deadening sound is the goal and doing so without a sh*tpile of added weight would be nice. Would you recommend adding that heavy duty velcro to affix it or using some sort of spray adhesive? |
Mikey914 |
Jun 28 2021, 02:11 AM
Just to speak to the construction on the 914Rubber.com pad. We use an OEM style felt pad that is treating to make it more water resistant. Instead of using a tar, we use a rubber that will work to absorb sound, is more fire resistant and is MUCH lighter than the OEM pads. Once installed it looks pretty stock. Our cost on these will be going up shortly due to materials cost should be about $20 but until we sell the product we were able to make at the lower cost you save. I don't care too much about stock look. Deadening sound is the goal and doing so without a sh*tpile of added weight would be nice. Would you recommend adding that heavy duty velcro to affix it or using some sort of spray adhesive? You can do the velcro if you think you will get dirt and crud behind it. Personally I spairingly use the weldwood contact adhesive. It won't be going anywhere and heat is not an issue. Mark |
Lo-Fi Version | Time is now: 7th June 2024 - 08:34 AM |
