Double spring/.460 + lift cam, Hard to turn over engine? |
rfinegan |
Jun 29 2021, 06:28 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I am working on my 2056 build and have been setting my valve and pushrod geometry with light weight springs and turning the engine over by the flywheel with the plugs out with out issue. This is one cylinder / valve at a time.
I now have the double springs installed and started to install the pushrods and rockers. I am finding the valve springs on the cam lobes will roll the engine backwards when releasing the fly wheel. Multiple valves lashed I need 2 hands( slightly exaggerated ) to turn the engine over. Still no plugs. Flywheel holder /turner is better but.... Just checking is if this is still "NORMAL" as I button up the valve covers shortly -Best Regards -Robert |
Mark Henry |
Jun 29 2021, 10:54 AM
I am working on my 2056 build and have been setting my valve and pushrod geometry with light weight springs and turning the engine over by the flywheel with the plugs out with out issue. This is one cylinder / valve at a time. I now have the double springs installed and started to install the pushrods and rockers. I am finding the valve springs on the cam lobes will roll the engine backwards when releasing the fly wheel. Multiple valves lashed I need 2 hands( slightly exaggerated ) to turn the engine over. Still no plugs. Flywheel holder /turner is better but.... Just checking is if this is still "NORMAL" as I button up the valve covers shortly -Best Regards -Robert Install all the springs and it should't roll back. Yes it will take some effort, but there should be no binding rolling it over 720 degrees. Did you check clearance between the guide and retainer? What height and pounds did you set the springs for? |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:04 AM |
