GeorgeKopf |
Member ![]() ![]() Group: Members Posts: 233 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region ![]() |
I'm going through my wiring harness with a fine tooth comb and I have a couple of questions.
In this picture: I. What are these four connectors for? I think they are for the center console. Is that right? II. Is this green wire for the parking brake switch? III. Are the brown wires for the door switches and the black for the internal light. ![]() What is this for? I believe it mounts somewhere under one of the seats and is used to connect the harness wires to the door switches. Where does it mount? Which accessories are connected through it? ![]() The plastic connector holder on my turn signal switch is very brittle. I don't suppose there are any aftermarket replacements? ![]() Lastly, where can I purchase all new grommets for the wiring harness? Thanks. George |
GeorgeKopf |
Thank you Jim.
Is moving the fuel pump under the gas tank a common mod? Is that standard on the 75 and 76 914s. George |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,974 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Thank you Jim. Is moving the fuel pump under the gas tank a common mod? Is that standard on the 75 and 76 914s. George Yes. It prevents the vapor lock that many 914's with fuel pumps in the engine compartment suffered with. It also routes pressurized fuel in the center tunnel through the cabin. Personally I feel safer with the stock FP 70-74 location. If vapor lock is an issue, the factory service bulletin describes a fix that works well. |
Lo-Fi Version | Time is now: 15th July 2025 - 11:46 AM |
