> correct value for warm CHT reading (ohms)
brant
post Jul 7 2021, 09:14 AM
so my CHT reading was 76 ohms - hot (at 180F oil temp)
I'm reading 2 different things.. on the Brad anders site
one saying that a warm reading should be below 100 ohms
but then the table shows this: for 210F
Sensor Temp = 39 deg. F Temp = 61 deg. F Temp = 210 deg F
0 280 130 003 6.10 K ohms 2.94 K ohms 199.3 ohms
0 280 130 012 NA 2.85 K ohms 191.2 ohms
0 280 130 017 3.63 K ohms 1.74 K ohms 124.7 ohms
I'd love some input from Djet folks about what numbers you see on a warm motor?
brant
914_teener
post Jul 8 2021, 12:22 PM
Stock dizzy?
brant
post Jul 8 2021, 02:19 PM
QUOTE(914_teener @ Jul 8 2021, 12:22 PM) *
Stock dizzy?
this motor was Jason's from AZ
he had it built... and when I bought it from him it was a full Djet motor
he told me the shop had put a "mild" FI cam into it, but don't know which one
I don’t think it would be a raby cam. Probably a webcam
the cam absolutely runs out of lift at 5900
I never typically shift above 5600 as there is no reason
but I rode it out... for the purpose of seeing what the AFR did.
its stock dizzy... all stock injection... the only modification is to the ignition with a Hall Effect, pick up... and a crane/highwire (?) CDI type box.
I'm betting the slightly lean highway condition is the reason I get 32MPG @85
but that I can improve on it some...
I also now believe that my plugs are fine... and yes I might be seeing a tiny bit of a lean condition on the highway.. but doubt the plugs can even show much difference
brant
- Lo-Fi Version Time is now: 8th November 2026 - 06:13 PM
