> correct value for warm CHT reading (ohms)
brant
post Jul 7 2021, 09:14 AM
so my CHT reading was 76 ohms - hot (at 180F oil temp)
I'm reading 2 different things.. on the Brad anders site
one saying that a warm reading should be below 100 ohms
but then the table shows this: for 210F
Sensor Temp = 39 deg. F Temp = 61 deg. F Temp = 210 deg F
0 280 130 003 6.10 K ohms 2.94 K ohms 199.3 ohms
0 280 130 012 NA 2.85 K ohms 191.2 ohms
0 280 130 017 3.63 K ohms 1.74 K ohms 124.7 ohms
I'd love some input from Djet folks about what numbers you see on a warm motor?
brant
914_teener
post Jul 8 2021, 12:22 PM
Stock dizzy?
brant
post Jul 8 2021, 02:19 PM
QUOTE(914_teener @ Jul 8 2021, 12:22 PM) *
Stock dizzy?
this motor was Jason's from AZ
he had it built... and when I bought it from him it was a full Djet motor
he told me the shop had put a "mild" FI cam into it, but don't know which one
I don’t think it would be a raby cam. Probably a webcam
the cam absolutely runs out of lift at 5900
I never typically shift above 5600 as there is no reason
but I rode it out... for the purpose of seeing what the AFR did.
its stock dizzy... all stock injection... the only modification is to the ignition with a Hall Effect, pick up... and a crane/highwire (?) CDI type box.
I'm betting the slightly lean highway condition is the reason I get 32MPG @85
but that I can improve on it some...
I also now believe that my plugs are fine... and yes I might be seeing a tiny bit of a lean condition on the highway.. but doubt the plugs can even show much difference
brant
914_teener
post Jul 9 2021, 10:34 AM
QUOTE(brant @ Jul 8 2021, 01:19 PM) *
Stock dizzy?
brant
My thought was this Brant:
The stock dizzy, and I'm assuming yours still uses the trigger points to fire the injectors,makes a huge difference with regards to wear and alignment of those things as far as injection pulse goes. That'd be my experience.
I too , am surprised that yours still makes any power at or even near 5900K
With regards to compression...according to Raby he never recommended to go over 8.5:1 when running D-jet, so I don't know what yours is. That what I remember hearing. Not to mention heads.....they are the heart of a T4 and its weakest link.
In any case, I eventually ditched the stock dizzy for reliablilty sake. No more points and no more trigger points.
Car ran like a top after I got the mixture right. I saw variations up to 9k feet when driving in the local mountains but not at sustained speeds up there on the top of the Mogollon plateau like you do.l
I don't know what you can do other than that and or a potentiometer on the CHT lead.
Those be my .02.
brant
post Jul 9 2021, 03:06 PM
QUOTE(914_teener @ Jul 9 2021, 10:34 AM) *
Stock dizzy?
brant
Those be my .02.
great 2 cents!
and I know I've never adjusted the trigger points.
they have to be 50 years old by now
so a very good idea of something to check
did you go with the blue tooth/fancy new distributor that everyone is using?
brant
- Lo-Fi Version Time is now: 8th November 2026 - 06:13 PM
