mobymutt |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada ![]() |
I just swapped out my 1.8L for a 1.7L (so I could rebuild the 1.8L), and I can't find the wire that goes to the pressure switch.
I've got carbs, so the wire harnesses have a zillion unused wires. But I thought there would be a wire with a dangling connector somewhere nearby... apparently not. The car is a '74. From the wiring diagram, it looks like the wire should be green with red stripes, but I can't find that either. Can anybody tell me how I might go about finding the correct wire to hook up? Maybe the physical location of the wire run to start? Or where it comes from, or what other wires it would be with? Any help is appreciated, thank you! |
mobymutt |
914world to the rescue again! Thank you everyone!
Found the relevant wire wrapped under layers of extremely old black tape. This tells me a couple of things: -the PO's mechanic didn't concern himself with irrelevancies like oil pressure -the current owner was too daft to notice that it had never been hooked up before. So I now have new pretty green light on my dash when I turn the power on! With the engine running, should that green light turn off, or stay on? |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,833 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Lo-Fi Version | Time is now: 15th July 2025 - 11:40 AM |
