Fuel Pump specs for 46 ida weber 2.5litre and larger race engines.? |
jmz |
Jul 1 2021, 11:14 AM
Member Group: Members Posts: 165 Joined: 11-April 16 From: Lone Star State Member No.: 19,886 Region Association: None |
I'm having a fuel pressure issue after being on track for a few laps. It seems like the float bowls are being sucked dry....
Current pump is a Carter I believe the model to be 4060. This shows to be a 50 GPH pump. The car has 46 IDA webers is 2.5 litre high compression. ...also have a 2.8 that I run sometimes. I would think 50gph would be enough so maybe something else is going on? Anyone have any thoughts? |
campbellcj |
Jul 14 2021, 07:45 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
FWIW the most recent of several fueling issues I've had was an intermittent wiring connection to the pump, which took a while to find. The symptom was similar ie everything fine then suddenly no fuel, then fine again.
I've been running the Holley Red pump which is rated 97gph with a 2.7/Weber46 engine and no volume probs whatsoever. Also have the PMS/FuelSafe cell which works well in terms of sloshing and pickup. Two filters, large one near the pump and small inline one just before the carbs. Previously I have also had clogged jet issues which are no fun either, but nowhere near as bad as total fuel cutout. |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:11 AM |
