| Halfnelson |
Jul 23 2021, 06:51 AM
Member ![]() ![]() Group: Members Posts: 72 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
Help - my new to me 1973 1.7 Djet came running really sweet, but almost immediately developed the 'hunting tick-over' of lean running / air leak. We replaced all the vacuum pipes, found one of the inlet gaskets had a very slight leak. Seems somewhere along the line things have been tweaked to compensate for the leaks so that now they're cured, the car is running super rich. Having had a L-jet for years the Djet is new to me so any advice on where to start first would be much appreciated. Thanks Chris
| Dave_Darling |
Jul 24 2021, 01:05 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Step 1: Check the ignition system. Yes, seriously. Make sure the timing and dwell are in spec, and that you're getting a nice fat white happy spark.
It's amazing how many "FI problems" (and "carb problems"!) are actually caused by ignition system issues. Step 2: Check the valve adjustments. Valves that are out of whack can cause odd-seeming problems. For instance, an intake valve that doesn't close all the way can cause a very rich mixture. (Don't ask how I know that.) Then move on to testing the parts of the FI system. --DD |
| Halfnelson |
Jul 24 2021, 07:44 AM
Many thanks for all the suggestions - plenty to work our way through on Monday and I'll report back. Had a read through other similar threads - one that said CHT sensors don't often go bad - is it more likely a case of bad connections?
Halfnelson Help - Djet running way too rich Jul 23 2021, 06:51 AM
rfinegan Try adjusting the Idle mixture knob on the ECU. I ... Jul 23 2021, 07:35 AM
jrmdir Welcome to the D-Jet rich mixture madness. I'm... Jul 23 2021, 08:19 AM
dr914@autoatlanta.com SUPER rich could be blocked fuel return, bad valve... Jul 23 2021, 08:46 AM
ctc911ctc That is a beautiful car!
SUPER rich could ... Jul 23 2021, 09:43 AM
Olympic 914 Pull a vacuum on your MPS
Make sure your diaphragm... Jul 23 2021, 11:11 AM
rjames
Make sure your diaphrag... Jul 23 2021, 12:02 PM
jrmdir Hi Halfnelson: Hope this doesn't amount to hij... Jul 24 2021, 10:05 AM
rjames Calibrating the MPS correctly requires being able ... Jul 24 2021, 10:19 AM
brant
Calibrating the MPS correctly requires being able... Jul 24 2021, 01:09 PM
mgphoto
Calibrating the MPS correctly requires being able... Sep 6 2022, 01:00 PM
jrmdir Thanks for the feedback. Just to be clear, I'm... Jul 24 2021, 02:14 PM
Dave_Darling Also worth checking the fuel pressure. Should be ... Jul 24 2021, 07:20 PM
r_towle Clean the inner parts in the distributor.
The adva... Jul 24 2021, 09:39 PM
Halfnelson Thanks for everyone's feedback on this. I... Aug 11 2021, 08:45 AM
Rand I would have bet MPS. How was it tested?
A simple... Aug 11 2021, 06:30 PM
Halfnelson OK - so not sorted after all. :headbang:
After ... Aug 20 2021, 07:53 AM
Bartlett 914
After... Aug 20 2021, 07:58 AM
Halfnelson Thanks Mark - have replaced the CHT but will test ... Aug 20 2021, 09:34 AM
rjames I had a similar situation and it turned out to be ... Aug 20 2021, 09:35 AM
Halfnelson
I had a similar situation and it turned out to be... Aug 20 2021, 09:54 AM
rjames
I had a similar situation and it turned out to b... Aug 20 2021, 10:15 AM
Rand What was the difference in idle when you pulled th... Aug 20 2021, 12:58 PM
rjames
What was the difference in idle when you pulled t... Aug 20 2021, 02:23 PM
Rand
What was the difference in idle when you pulled ... Aug 24 2021, 09:10 PM
rjames
[quote name='rjames' post='2939526' date='Aug 20 ... Aug 24 2021, 09:48 PM
Rand
Yup- I had it backwards. After all the DJet and M... Aug 24 2021, 09:52 PM
emerygt350 Just out of curiosity, have you checked which inje... Aug 20 2021, 04:44 PM
Halfnelson
Just out of curiosity, have you checked which inj... Aug 23 2021, 07:57 AM
Halfnelson Lots of questions spring to mind like how it was e... Aug 23 2021, 08:02 AM
emerygt350 I have 1... And it is yellow.
I bought those n... Aug 23 2021, 06:19 PM
emerygt350
The left side is the 2.0 Aug 23 2021, 06:27 PM
steuspeed Wrong injectors.. amazing! I bought a set of S... Aug 23 2021, 10:34 PM
ChrisFoley Those look like 1.8L injectors, for L-Jet. Someone... Aug 24 2021, 09:52 AM
Halfnelson
Those look like 1.8L injectors, for L-Jet. Someon... Aug 25 2021, 09:37 AM
emerygt350 Wow, the plot thickens. Aug 24 2021, 11:23 AM
emerygt350 The one you are looking for is the fj114. 59 doll... Aug 25 2021, 10:09 AM
Halfnelson I'm resurrecting this thread if that's ok ... Sep 6 2022, 10:10 AM
JeffBowlsby Have you checked your CSV for leakage? Sep 6 2022, 10:30 AM
JamesM
:agree:... Sep 6 2022, 11:52 AM
Halfnelson
:agree... Sep 6 2022, 12:57 PM
rjames I spent well over a year troubleshooting a similar... Sep 6 2022, 11:19 AM
emerygt350 Yeah, check that cold start valve.
Any chance you... Sep 6 2022, 01:01 PM
Halfnelson
Any chance yo... Sep 6 2022, 01:07 PM
Lockwodo
Any chance y... Sep 7 2022, 04:38 PM
emerygt350
[quote name='Halfnelson' post='3027513' date='Sep... Sep 7 2022, 05:30 PM
mgphoto Pull one side of the fuel rail off while the engin... Sep 6 2022, 01:10 PM
emerygt350
Pull one side of the fuel rail off while the engi... Sep 6 2022, 01:38 PM
JeffBowlsby Two other things to check:
TS2 - cyl head temp se... Sep 6 2022, 01:53 PM
rjames
@emerygt350 Not true. What he is experiencing ... Sep 6 2022, 02:24 PM
emerygt350
[b]@[url=http://www.914world.com/bbs2/index.ph... Sep 6 2022, 02:40 PM
rjames
[b]@[url=http://www.914world.com/bbs2/index.p... Sep 6 2022, 03:00 PM
emerygt350 I guess there is no reason it couldn't go outs... Sep 6 2022, 07:00 PM
914_teener Time Out.
There is a difference between testing a... Sep 7 2022, 07:43 PM
Halfnelson Finally got a chance to get to the 914 so can conf... Sep 18 2022, 11:42 AM
emerygt350 Possibly but they look ok. Sep 18 2022, 05:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:44 PM |
