| BeatNavy |
Aug 2 2021, 12:00 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
I've had a couple of oil leaks on my fresh 2270, the most annoying of which seemed to come from the area of the oil pump and gradually got worse. Oil would drip on the underside of the engine mount cross bar in the center and air flow would then scatter it around (on engine, gearbox, exhaust, etc.). I bit the bullet this weekend and pulled the engine.
I then pulled off just the oil pump cover. I gather it's best to leave the pump housing itself in place if that's not the issue. I've got pics below showing where the lower oil pump gear has really ground against the cover, and a closeup of the gear itself showing wear on the gear. That edge on the inside lip of the gear is actually sharp to the touch. I would be guessing that metal on metal contact is not awesome right in the heart of the lubrication system, but I have also heard that those pumps do press against the cover. Not sure if this is the cause of, or contributor to, my oil leak, but how does this look to the braintrust? Assuming this is considered "acceptable," any tips for sealing this bad boy up so it doesn't leak? I've seen McMark's video.... Here's a shot of the pump with the cover on. Oil can be seen collecting at the bottom on the lip. If I had to guess it looks like it actually came out around the studs, as the nuts were pretty oily on the inside. ![]() Cover showing wear... ![]() Oil pump gears.... Closeup of the bottom gear. It's actually worn a sharp lip on that lower gear. |
| ejm |
Aug 2 2021, 01:31 PM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,716 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The galling on the cover and lower gear is not typical wear. Try to determine why it happened and replace the complete pump.
BeatNavy Oil Pump Leak Questions Aug 2 2021, 12:00 PM
VaccaRabite That pin seems like its in there a good bit. I do... Aug 2 2021, 12:17 PM
BeatNavy
That pin seems like its in there a good bit. I d... Aug 2 2021, 01:13 PM
VaccaRabite
What would cause the pin to drift?
The pin dri... Aug 2 2021, 02:41 PM
930cabman
The pin dr... Aug 2 2021, 05:15 PM
bkrantz
[quote name='VaccaRabite' post='2935085' date='Au... Aug 2 2021, 08:27 PM
914Sixer Bug type pumps always used sealing nut with the sa... Aug 2 2021, 12:26 PM
brant
Bug type pumps always used sealing nut with the s... Aug 2 2021, 08:59 PM
BeatNavy Ok, so it looks like a new oil pump may be in my n... Aug 2 2021, 06:17 PM
BeatNavy I see these on Ebay Brant:
https://www.ebay.com/i... Aug 3 2021, 07:10 AM
brant Thanks again Rob! Aug 3 2021, 07:22 AM
maf914 What type oil pump is this? Is it a Type 1 Schade... Aug 3 2021, 10:14 AM
BeatNavy It is a Schadek. I purchased a replacement pump a... Aug 3 2021, 10:47 AM
brant
It is a Schadek. I purchased a replacement pump ... Aug 3 2021, 10:56 AM
rfinegan http://vwparts.aircooled.net/8mm-Self-Seal...111-1... Aug 3 2021, 11:05 AM
rfinegan
http://vwparts.aircooled.net/8mm-Self-Seal...111-... Aug 3 2021, 11:23 AM
autopro
[quote name='rfinegan' post='2935277' date='Aug 3... Aug 3 2021, 06:01 PM
BeatNavy Received my new modified Schadek 30mm pump, new co... Aug 8 2021, 03:54 PM
rfinegan Did you go with the Modified Pump from EMW (Jorge)... Aug 8 2021, 04:19 PM
BeatNavy
Did you go with the Modified Pump from EMW (Jorge... Aug 8 2021, 04:25 PM
rfinegan If you did not see any oil pressure problems, it ... Aug 8 2021, 04:35 PM
BeatNavy Ok, so the pump housing came off the case easier t... Aug 9 2021, 09:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:46 PM |
