> Help - Djet running way too rich
Halfnelson
post Jul 23 2021, 06:51 AM
Region Association: England
Help - my new to me 1973 1.7 Djet came running really sweet, but almost immediately developed the 'hunting tick-over' of lean running / air leak. We replaced all the vacuum pipes, found one of the inlet gaskets had a very slight leak. Seems somewhere along the line things have been tweaked to compensate for the leaks so that now they're cured, the car is running super rich. Having had a L-jet for years the Djet is new to me so any advice on where to start first would be much appreciated. Thanks ChrisAttached Image
Halfnelson
post Aug 11 2021, 08:45 AM
Thanks for everyone's feedback on this. I've finally got an update on things. After a couple of false dawns I'm hoping we've nailed the issue. Total work included:
Checking MPS - OK
New fuel lines, filter and fuel pump
Sorting the ignition as the spark was weak - so new coil etc
Going through all wiring and fuses
New CHT sender
New plugs for injectors
My guess is multiple small faults adding up to a lot of head scratching when we thought the problem was solved... only for it not to be.
Done a few local trips including a car show at the weekend. Fingers crossed now for a longer test drive.
Halfnelson   Help - Djet running way too rich   Jul 23 2021, 06:51 AM
rfinegan   Try adjusting the Idle mixture knob on the ECU. I ...   Jul 23 2021, 07:35 AM
jrmdir   Welcome to the D-Jet rich mixture madness. I'm...   Jul 23 2021, 08:19 AM
dr914@autoatlanta.com   SUPER rich could be blocked fuel return, bad valve...   Jul 23 2021, 08:46 AM
ctc911ctc   That is a beautiful car! SUPER rich could ...   Jul 23 2021, 09:43 AM
Olympic 914   Pull a vacuum on your MPS Make sure your diaphragm...   Jul 23 2021, 11:11 AM
rjames   Pull a vacuum on your MPS Make sure your diaphrag...   Jul 23 2021, 12:02 PM
Dave_Darling   Step 1: Check the ignition system. Yes, seriousl...   Jul 24 2021, 01:05 AM
Halfnelson   Many thanks for all the suggestions - plenty to wo...   Jul 24 2021, 07:44 AM
jrmdir   Hi Halfnelson: Hope this doesn't amount to hij...   Jul 24 2021, 10:05 AM
rjames   Calibrating the MPS correctly requires being able ...   Jul 24 2021, 10:19 AM
brant   Calibrating the MPS correctly requires being able...   Jul 24 2021, 01:09 PM
mgphoto   Calibrating the MPS correctly requires being able...   Sep 6 2022, 01:00 PM
jrmdir   Thanks for the feedback. Just to be clear, I'm...   Jul 24 2021, 02:14 PM
Dave_Darling   Also worth checking the fuel pressure. Should be ...   Jul 24 2021, 07:20 PM
r_towle   Clean the inner parts in the distributor. The adva...   Jul 24 2021, 09:39 PM
Halfnelson   Thanks for everyone's feedback on this. I...   Aug 11 2021, 08:45 AM
Rand   I would have bet MPS. How was it tested? A simple...   Aug 11 2021, 06:30 PM
Halfnelson   OK - so not sorted after all. :headbang: After ...   Aug 20 2021, 07:53 AM
Bartlett 914   OK - so not sorted after all. :headbang: After...   Aug 20 2021, 07:58 AM
Halfnelson   Thanks Mark - have replaced the CHT but will test ...   Aug 20 2021, 09:34 AM
rjames   I had a similar situation and it turned out to be ...   Aug 20 2021, 09:35 AM
Halfnelson   I had a similar situation and it turned out to be...   Aug 20 2021, 09:54 AM
rjames   I had a similar situation and it turned out to b...   Aug 20 2021, 10:15 AM
Rand   What was the difference in idle when you pulled th...   Aug 20 2021, 12:58 PM
rjames   What was the difference in idle when you pulled t...   Aug 20 2021, 02:23 PM
Rand   What was the difference in idle when you pulled ...   Aug 24 2021, 09:10 PM
rjames   [quote name='rjames' post='2939526' date='Aug 20 ...   Aug 24 2021, 09:48 PM
Rand   Yup- I had it backwards. After all the DJet and M...   Aug 24 2021, 09:52 PM
emerygt350   Just out of curiosity, have you checked which inje...   Aug 20 2021, 04:44 PM
Halfnelson   Just out of curiosity, have you checked which inj...   Aug 23 2021, 07:57 AM
Halfnelson   Lots of questions spring to mind like how it was e...   Aug 23 2021, 08:02 AM
emerygt350   I have 1... And it is yellow. I bought those n...   Aug 23 2021, 06:19 PM
emerygt350   The left side is the 2.0   Aug 23 2021, 06:27 PM
steuspeed   Wrong injectors.. amazing! I bought a set of S...   Aug 23 2021, 10:34 PM
ChrisFoley   Those look like 1.8L injectors, for L-Jet. Someone...   Aug 24 2021, 09:52 AM
Halfnelson   Those look like 1.8L injectors, for L-Jet. Someon...   Aug 25 2021, 09:37 AM
emerygt350   Wow, the plot thickens.   Aug 24 2021, 11:23 AM
emerygt350   The one you are looking for is the fj114. 59 doll...   Aug 25 2021, 10:09 AM
Halfnelson   I'm resurrecting this thread if that's ok ...   Sep 6 2022, 10:10 AM
JeffBowlsby   Have you checked your CSV for leakage?   Sep 6 2022, 10:30 AM
JamesM   Have you checked your CSV for leakage? :agree:...   Sep 6 2022, 11:52 AM
Halfnelson   Have you checked your CSV for leakage? :agree...   Sep 6 2022, 12:57 PM
rjames   I spent well over a year troubleshooting a similar...   Sep 6 2022, 11:19 AM
emerygt350   Yeah, check that cold start valve. Any chance you...   Sep 6 2022, 01:01 PM
Halfnelson   Yeah, check that cold start valve. Any chance yo...   Sep 6 2022, 01:07 PM
Lockwodo   Yeah, check that cold start valve. Any chance y...   Sep 7 2022, 04:38 PM
emerygt350   [quote name='Halfnelson' post='3027513' date='Sep...   Sep 7 2022, 05:30 PM
mgphoto   Pull one side of the fuel rail off while the engin...   Sep 6 2022, 01:10 PM
emerygt350   Pull one side of the fuel rail off while the engi...   Sep 6 2022, 01:38 PM
JeffBowlsby   Two other things to check: TS2 - cyl head temp se...   Sep 6 2022, 01:53 PM
rjames   @emerygt350 Not true. What he is experiencing ...   Sep 6 2022, 02:24 PM
emerygt350   [b]@[url=http://www.914world.com/bbs2/index.ph...   Sep 6 2022, 02:40 PM
rjames   [b]@[url=http://www.914world.com/bbs2/index.p...   Sep 6 2022, 03:00 PM
emerygt350   I guess there is no reason it couldn't go outs...   Sep 6 2022, 07:00 PM
914_teener   Time Out. There is a difference between testing a...   Sep 7 2022, 07:43 PM
Halfnelson   Finally got a chance to get to the 914 so can conf...   Sep 18 2022, 11:42 AM
emerygt350   Possibly but they look ok.   Sep 18 2022, 05:09 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:28 PM
