> 73 2.0 aux air routing
emerygt350
post Aug 12 2021, 02:28 PM
Just trying to make sure everything is right and I noticed my routing seems different than Chilton's diagrams (terrible as they are).
My aar goes from the passenger pointing top bit to a port on the plenum near where the t is for the decel valve hoses.
The lower, driver pointing aar port goes to the cold start valve (that seems right).
Needless to say I don't think having it go to two ports on the plenum is right. Suggestions? What should be going to that port on the plenum if I pull the hose from the aar? And all of my ports on the air cleaner are occupied so where should that hose from the aar connect?
emerygt350
post Aug 13 2021, 10:10 AM
THe aux air is working perfectly, however, my pcv is not. That might explain the bad passive rerouting.
Cleaned the PCV but no good, just way too much air gets through. Plug it with my thumb and it idles perfectly. Going to try that corolla PCV cheat.
- Lo-Fi Version Time is now: 4th July 2025 - 07:54 AM
