emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,982 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Just trying to make sure everything is right and I noticed my routing seems different than Chilton's diagrams (terrible as they are).
My aar goes from the passenger pointing top bit to a port on the plenum near where the t is for the decel valve hoses. The lower, driver pointing aar port goes to the cold start valve (that seems right). Needless to say I don't think having it go to two ports on the plenum is right. Suggestions? What should be going to that port on the plenum if I pull the hose from the aar? And all of my ports on the air cleaner are occupied so where should that hose from the aar connect? |
Sea Rooster |
Member ![]() ![]() Group: Members Posts: 117 Joined: 8-March 18 From: Nashville, TN Member No.: 21,948 Region Association: South East States ![]() ![]() |
Following your progress since I have a similar issue. I have a low idle until it's warm. I've used 3 separate working AAR vales with no luck.
Lo-Fi Version | Time is now: 4th July 2025 - 08:40 AM |
