> Help - Djet running way too rich
Halfnelson
post Jul 23 2021, 06:51 AM
Region Association: England
Help - my new to me 1973 1.7 Djet came running really sweet, but almost immediately developed the 'hunting tick-over' of lean running / air leak. We replaced all the vacuum pipes, found one of the inlet gaskets had a very slight leak. Seems somewhere along the line things have been tweaked to compensate for the leaks so that now they're cured, the car is running super rich. Having had a L-jet for years the Djet is new to me so any advice on where to start first would be much appreciated. Thanks ChrisAttached Image
Halfnelson
post Aug 11 2021, 08:45 AM
Thanks for everyone's feedback on this. I've finally got an update on things. After a couple of false dawns I'm hoping we've nailed the issue. Total work included:
Checking MPS - OK
New fuel lines, filter and fuel pump
Sorting the ignition as the spark was weak - so new coil etc
Going through all wiring and fuses
New CHT sender
New plugs for injectors
My guess is multiple small faults adding up to a lot of head scratching when we thought the problem was solved... only for it not to be.
Done a few local trips including a car show at the weekend. Fingers crossed now for a longer test drive.
Halfnelson
post Aug 20 2021, 07:53 AM
OK - so not sorted after all. (IMG:style_emoticons/default/headbang.gif)
After about half a dozen test drives with stops, restarts, refuelling etc went down the road to today, car stalled at junction and refused to restart. Strong petrol smell. Disconnected injectors and it would at least try and start but still lots of fuel still coming out of the exhaust so recovered home.
What's adding all the excess fuel with the injectors disconnected? Could the cold start injector be faulty?
Bartlett 914
post Aug 20 2021, 07:58 AM
QUOTE(Halfnelson @ Aug 20 2021, 08:53 AM) *
I would suspect an intermittent CHT or simply a poor connection with it
Halfnelson
post Aug 20 2021, 09:34 AM
Thanks Mark - have replaced the CHT but will test that again and also check the connection.
Halfnelson   Help - Djet running way too rich   Jul 23 2021, 06:51 AM
rfinegan   Try adjusting the Idle mixture knob on the ECU. I ...   Jul 23 2021, 07:35 AM
jrmdir   Welcome to the D-Jet rich mixture madness. I'm...   Jul 23 2021, 08:19 AM
dr914@autoatlanta.com   SUPER rich could be blocked fuel return, bad valve...   Jul 23 2021, 08:46 AM
ctc911ctc   That is a beautiful car! SUPER rich could ...   Jul 23 2021, 09:43 AM
Olympic 914   Pull a vacuum on your MPS Make sure your diaphragm...   Jul 23 2021, 11:11 AM
rjames   Pull a vacuum on your MPS Make sure your diaphrag...   Jul 23 2021, 12:02 PM
Dave_Darling   Step 1: Check the ignition system. Yes, seriousl...   Jul 24 2021, 01:05 AM
Halfnelson   Many thanks for all the suggestions - plenty to wo...   Jul 24 2021, 07:44 AM
jrmdir   Hi Halfnelson: Hope this doesn't amount to hij...   Jul 24 2021, 10:05 AM
rjames   Calibrating the MPS correctly requires being able ...   Jul 24 2021, 10:19 AM
brant   Calibrating the MPS correctly requires being able...   Jul 24 2021, 01:09 PM
mgphoto   Calibrating the MPS correctly requires being able...   Sep 6 2022, 01:00 PM
jrmdir   Thanks for the feedback. Just to be clear, I'm...   Jul 24 2021, 02:14 PM
Dave_Darling   Also worth checking the fuel pressure. Should be ...   Jul 24 2021, 07:20 PM
r_towle   Clean the inner parts in the distributor. The adva...   Jul 24 2021, 09:39 PM
Halfnelson   Thanks for everyone's feedback on this. I...   Aug 11 2021, 08:45 AM
Rand   I would have bet MPS. How was it tested? A simple...   Aug 11 2021, 06:30 PM
Halfnelson   OK - so not sorted after all. :headbang: After ...   Aug 20 2021, 07:53 AM
Bartlett 914   OK - so not sorted after all. :headbang: After...   Aug 20 2021, 07:58 AM
Halfnelson   Thanks Mark - have replaced the CHT but will test ...   Aug 20 2021, 09:34 AM
rjames   I had a similar situation and it turned out to be ...   Aug 20 2021, 09:35 AM
Halfnelson   I had a similar situation and it turned out to be...   Aug 20 2021, 09:54 AM
rjames   I had a similar situation and it turned out to b...   Aug 20 2021, 10:15 AM
Rand   What was the difference in idle when you pulled th...   Aug 20 2021, 12:58 PM
rjames   What was the difference in idle when you pulled t...   Aug 20 2021, 02:23 PM
Rand   What was the difference in idle when you pulled ...   Aug 24 2021, 09:10 PM
rjames   [quote name='rjames' post='2939526' date='Aug 20 ...   Aug 24 2021, 09:48 PM
Rand   Yup- I had it backwards. After all the DJet and M...   Aug 24 2021, 09:52 PM
emerygt350   Just out of curiosity, have you checked which inje...   Aug 20 2021, 04:44 PM
Halfnelson   Just out of curiosity, have you checked which inj...   Aug 23 2021, 07:57 AM
Halfnelson   Lots of questions spring to mind like how it was e...   Aug 23 2021, 08:02 AM
emerygt350   I have 1... And it is yellow. I bought those n...   Aug 23 2021, 06:19 PM
emerygt350   The left side is the 2.0   Aug 23 2021, 06:27 PM
steuspeed   Wrong injectors.. amazing! I bought a set of S...   Aug 23 2021, 10:34 PM
ChrisFoley   Those look like 1.8L injectors, for L-Jet. Someone...   Aug 24 2021, 09:52 AM
Halfnelson   Those look like 1.8L injectors, for L-Jet. Someon...   Aug 25 2021, 09:37 AM
emerygt350   Wow, the plot thickens.   Aug 24 2021, 11:23 AM
emerygt350   The one you are looking for is the fj114. 59 doll...   Aug 25 2021, 10:09 AM
Halfnelson   I'm resurrecting this thread if that's ok ...   Sep 6 2022, 10:10 AM
JeffBowlsby   Have you checked your CSV for leakage?   Sep 6 2022, 10:30 AM
JamesM   Have you checked your CSV for leakage? :agree:...   Sep 6 2022, 11:52 AM
Halfnelson   Have you checked your CSV for leakage? :agree...   Sep 6 2022, 12:57 PM
rjames   I spent well over a year troubleshooting a similar...   Sep 6 2022, 11:19 AM
emerygt350   Yeah, check that cold start valve. Any chance you...   Sep 6 2022, 01:01 PM
Halfnelson   Yeah, check that cold start valve. Any chance yo...   Sep 6 2022, 01:07 PM
Lockwodo   Yeah, check that cold start valve. Any chance y...   Sep 7 2022, 04:38 PM
emerygt350   [quote name='Halfnelson' post='3027513' date='Sep...   Sep 7 2022, 05:30 PM
mgphoto   Pull one side of the fuel rail off while the engin...   Sep 6 2022, 01:10 PM
emerygt350   Pull one side of the fuel rail off while the engi...   Sep 6 2022, 01:38 PM
JeffBowlsby   Two other things to check: TS2 - cyl head temp se...   Sep 6 2022, 01:53 PM
rjames   @emerygt350 Not true. What he is experiencing ...   Sep 6 2022, 02:24 PM
emerygt350   [b]@[url=http://www.914world.com/bbs2/index.ph...   Sep 6 2022, 02:40 PM
rjames   [b]@[url=http://www.914world.com/bbs2/index.p...   Sep 6 2022, 03:00 PM
emerygt350   I guess there is no reason it couldn't go outs...   Sep 6 2022, 07:00 PM
914_teener   Time Out. There is a difference between testing a...   Sep 7 2022, 07:43 PM
Halfnelson   Finally got a chance to get to the 914 so can conf...   Sep 18 2022, 11:42 AM
emerygt350   Possibly but they look ok.   Sep 18 2022, 05:09 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:05 PM
