> Help - Djet running way too rich
Halfnelson
post Jul 23 2021, 06:51 AM
Region Association: England
Help - my new to me 1973 1.7 Djet came running really sweet, but almost immediately developed the 'hunting tick-over' of lean running / air leak. We replaced all the vacuum pipes, found one of the inlet gaskets had a very slight leak. Seems somewhere along the line things have been tweaked to compensate for the leaks so that now they're cured, the car is running super rich. Having had a L-jet for years the Djet is new to me so any advice on where to start first would be much appreciated. Thanks ChrisAttached Image
rjames
post Aug 20 2021, 09:35 AM
I'm made of metal
I had a similar situation and it turned out to be a bad ECU. After 15-30 minutes of driving, the car would run super rich.
I still question your rebuilt MPS. You said you tested it, but just verifying that it holds vacuum isn't enough. You need the tools to adjust it (tangerine racing) and an AFR meter to dial it in. If the rich running your experiencing is intermittent, than you can probably check the MPS off of your list. But if it's always rich and swapping the ECU out doesn't change anything, then I suspect your MPS needs calibrating.
Quote jrmdir
In rebuilding the MPS, reestablishing the height of the center plunger involves an imprecise measurement. So this could be the issue. There is mention of uncovering the adjustment screw and then calibrating the MPS. But Mr Anders says this requires special equipment. It seems like this adjustment could easily impact the rich/lean situation. Has anyone tackled this calibration without test equipment?
@jrmdir At the very least you need the tools to adjust the MPS and and an AFR meter to set the MPS correctly.
Halfnelson
post Aug 20 2021, 09:54 AM
QUOTE(rjames @ Aug 20 2021, 04:35 PM) *
Thanks Robert - the MPS hasn't been rebuilt, still the original and holds vacuum - or at least was. Will double back and recheck.
How did you diagnose that it was the ECU? There seem to so many potential culprits and I had hoped these were already ticked off the list.
Halfnelson   Help - Djet running way too rich   Jul 23 2021, 06:51 AM
rfinegan   Try adjusting the Idle mixture knob on the ECU. I ...   Jul 23 2021, 07:35 AM
jrmdir   Welcome to the D-Jet rich mixture madness. I'm...   Jul 23 2021, 08:19 AM
dr914@autoatlanta.com   SUPER rich could be blocked fuel return, bad valve...   Jul 23 2021, 08:46 AM
ctc911ctc   That is a beautiful car! SUPER rich could ...   Jul 23 2021, 09:43 AM
Olympic 914   Pull a vacuum on your MPS Make sure your diaphragm...   Jul 23 2021, 11:11 AM
rjames   Pull a vacuum on your MPS Make sure your diaphrag...   Jul 23 2021, 12:02 PM
Dave_Darling   Step 1: Check the ignition system. Yes, seriousl...   Jul 24 2021, 01:05 AM
Halfnelson   Many thanks for all the suggestions - plenty to wo...   Jul 24 2021, 07:44 AM
jrmdir   Hi Halfnelson: Hope this doesn't amount to hij...   Jul 24 2021, 10:05 AM
rjames   Calibrating the MPS correctly requires being able ...   Jul 24 2021, 10:19 AM
brant   Calibrating the MPS correctly requires being able...   Jul 24 2021, 01:09 PM
mgphoto   Calibrating the MPS correctly requires being able...   Sep 6 2022, 01:00 PM
jrmdir   Thanks for the feedback. Just to be clear, I'm...   Jul 24 2021, 02:14 PM
Dave_Darling   Also worth checking the fuel pressure. Should be ...   Jul 24 2021, 07:20 PM
r_towle   Clean the inner parts in the distributor. The adva...   Jul 24 2021, 09:39 PM
Halfnelson   Thanks for everyone's feedback on this. I...   Aug 11 2021, 08:45 AM
Rand   I would have bet MPS. How was it tested? A simple...   Aug 11 2021, 06:30 PM
Halfnelson   OK - so not sorted after all. :headbang: After ...   Aug 20 2021, 07:53 AM
Bartlett 914   OK - so not sorted after all. :headbang: After...   Aug 20 2021, 07:58 AM
Halfnelson   Thanks Mark - have replaced the CHT but will test ...   Aug 20 2021, 09:34 AM
rjames   I had a similar situation and it turned out to be ...   Aug 20 2021, 09:35 AM
Halfnelson   I had a similar situation and it turned out to be...   Aug 20 2021, 09:54 AM
rjames   I had a similar situation and it turned out to b...   Aug 20 2021, 10:15 AM
Rand   What was the difference in idle when you pulled th...   Aug 20 2021, 12:58 PM
rjames   What was the difference in idle when you pulled t...   Aug 20 2021, 02:23 PM
Rand   What was the difference in idle when you pulled ...   Aug 24 2021, 09:10 PM
rjames   [quote name='rjames' post='2939526' date='Aug 20 ...   Aug 24 2021, 09:48 PM
Rand   Yup- I had it backwards. After all the DJet and M...   Aug 24 2021, 09:52 PM
emerygt350   Just out of curiosity, have you checked which inje...   Aug 20 2021, 04:44 PM
Halfnelson   Just out of curiosity, have you checked which inj...   Aug 23 2021, 07:57 AM
Halfnelson   Lots of questions spring to mind like how it was e...   Aug 23 2021, 08:02 AM
emerygt350   I have 1... And it is yellow. I bought those n...   Aug 23 2021, 06:19 PM
emerygt350   The left side is the 2.0   Aug 23 2021, 06:27 PM
steuspeed   Wrong injectors.. amazing! I bought a set of S...   Aug 23 2021, 10:34 PM
ChrisFoley   Those look like 1.8L injectors, for L-Jet. Someone...   Aug 24 2021, 09:52 AM
Halfnelson   Those look like 1.8L injectors, for L-Jet. Someon...   Aug 25 2021, 09:37 AM
emerygt350   Wow, the plot thickens.   Aug 24 2021, 11:23 AM
emerygt350   The one you are looking for is the fj114. 59 doll...   Aug 25 2021, 10:09 AM
Halfnelson   I'm resurrecting this thread if that's ok ...   Sep 6 2022, 10:10 AM
JeffBowlsby   Have you checked your CSV for leakage?   Sep 6 2022, 10:30 AM
JamesM   Have you checked your CSV for leakage? :agree:...   Sep 6 2022, 11:52 AM
Halfnelson   Have you checked your CSV for leakage? :agree...   Sep 6 2022, 12:57 PM
rjames   I spent well over a year troubleshooting a similar...   Sep 6 2022, 11:19 AM
emerygt350   Yeah, check that cold start valve. Any chance you...   Sep 6 2022, 01:01 PM
Halfnelson   Yeah, check that cold start valve. Any chance yo...   Sep 6 2022, 01:07 PM
Lockwodo   Yeah, check that cold start valve. Any chance y...   Sep 7 2022, 04:38 PM
emerygt350   [quote name='Halfnelson' post='3027513' date='Sep...   Sep 7 2022, 05:30 PM
mgphoto   Pull one side of the fuel rail off while the engin...   Sep 6 2022, 01:10 PM
emerygt350   Pull one side of the fuel rail off while the engi...   Sep 6 2022, 01:38 PM
JeffBowlsby   Two other things to check: TS2 - cyl head temp se...   Sep 6 2022, 01:53 PM
rjames   @emerygt350 Not true. What he is experiencing ...   Sep 6 2022, 02:24 PM
emerygt350   [b]@[url=http://www.914world.com/bbs2/index.ph...   Sep 6 2022, 02:40 PM
rjames   [b]@[url=http://www.914world.com/bbs2/index.p...   Sep 6 2022, 03:00 PM
emerygt350   I guess there is no reason it couldn't go outs...   Sep 6 2022, 07:00 PM
914_teener   Time Out. There is a difference between testing a...   Sep 7 2022, 07:43 PM
Halfnelson   Finally got a chance to get to the 914 so can conf...   Sep 18 2022, 11:42 AM
emerygt350   Possibly but they look ok.   Sep 18 2022, 05:09 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:04 PM
