> Help Please - 74 1.8 L Jet Issues, Either missing on #4 or won't start at all
SteveL
post Aug 21 2021, 07:00 PM
Basic Info:
74 1.8 L-Jet
Just installed new SMP injectors
Fuel pressure gauge installed.
I installed new injectors on 1 & 2 yesterday to replace a leaking injector, and it ran really nice after - better than before, leading me to believe that the old injects weren't 100%.
So, today I installed the other 2 new injectors on # 3 & 4 on passenger side. Now won't start at all. Fuel pressure gauge shows 36. I checked all fuel lines, all injector connectors, all vacuum lines. All looks good. Still no start. Time to step away, go get lunch.
Hour later, try again - she starts but backfiring really bad through exhaust. Check all vacuum lines again, all look good. Start it again, starts good, but is running rough. Idle is way high, adjust idle screw as it warms up to get idle down to 900. I think I may need a new cold start valve. Once warm, steady idle at 900. give it a little gas, and hold steady around 2700 rpm and it backfires through exhaust. To see if a specific cylinder is missing, I unplug wires one at a time. Pulling #4 makes no difference. #4 isn't firing.
Plenty of spark at the wire. I THINK the fuel injector plug tested ok. Took out injector and pointed it into a bottle. Had the lovely wife crank it over, no gas going into bottle.
AHA - bad injector. re-install old injector. Now no start at all. Check engine bay, and the hose on the old injector has also sprung a leak. WTF!!!!
Also, when testing the fuel injector plugs with a test light, one side was always hot, the other side would be lit with key on, then flash when engine cranked over.
Deep breath. Reinstall the new SMP injector again. No Start. Sit down at desk and throw myself on the merciful wisdom of the club.
Help me Obi-Wan Kenobi's, you're my only hope (kids are watching Star Wars in the other room...).
(IMG:style_emoticons/default/headbang.gif)
ndfrigi
post Aug 22 2021, 12:50 AM
36 fuel pressure seems high. I think it should only between 28 and 31 psi
wonkipop
post Aug 22 2021, 05:31 AM
QUOTE(ndfrigi @ Aug 22 2021, 12:50 AM) *
:agree:not
the pressure in a 1.8 is 2.5 bar + or - 0.2 bar.
or around 36 psi. so its about right at 35 maybe.
the proceedure for testing is in the factory manual.
you have to have a few things disconnected and operate the flap in the airflow meter with the ignition turned on. that pressures up the fuel pump. not sure you are necessarily testing the fuel pressure reading correctly, but ....
hmm. have to think about the rest of it you are describing.
someone here will know.
- Lo-Fi Version Time is now: 27th November 2026 - 08:49 AM
