| Halfnelson |
Jul 23 2021, 06:51 AM
Member ![]() ![]() Group: Members Posts: 72 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
Help - my new to me 1973 1.7 Djet came running really sweet, but almost immediately developed the 'hunting tick-over' of lean running / air leak. We replaced all the vacuum pipes, found one of the inlet gaskets had a very slight leak. Seems somewhere along the line things have been tweaked to compensate for the leaks so that now they're cured, the car is running super rich. Having had a L-jet for years the Djet is new to me so any advice on where to start first would be much appreciated. Thanks Chris
| Rand |
Aug 20 2021, 12:58 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
What was the difference in idle when you pulled the hose off at the MPS? Just give me that.
| rjames |
Aug 20 2021, 02:23 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,447 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
What was the difference in idle when you pulled the hose off at the MPS? Just give me that. Would it even run? IIRC, pulling the hose off would just cause it to go super lean, so if it ran I guess it would tell you that something else in the system is causing an uber rich condition, but it wouldn't rule out the MPS as a contributor. If it doesn't run, what would that tell us? If it's an intermittent issue or doesn't happen until the car warms up a little (I'm still not clear if that is the case here) then it's probably not the MPS. I haven't run across intermittent issues, or issues that happen only when the engine is cold or only when warm that ended up being the MPS. Seems like when it's the MPS that's the problem, the symptoms there all the time. |
| Rand |
Aug 24 2021, 09:10 PM
What was the difference in idle when you pulled the hose off at the MPS? Just give me that. Would it even run? IIRC, pulling the hose off would just cause it to go super lean, so if it ran I guess it would tell you that something else in the system is causing an uber rich condition, but it wouldn't rule out the MPS as a contributor. If it doesn't run, what would that tell us? If it's an intermittent issue or doesn't happen until the car warms up a little (I'm still not clear if that is the case here) then it's probably not the MPS. I haven't run across intermittent issues, or issues that happen only when the engine is cold or only when warm that ended up being the MPS. Seems like when it's the MPS that's the problem, the symptoms there all the time. Pulling the MPS hose does NOT cause lean, it causes full RICH. True, it should not run, it should immediately choke and die. I wasn't necessarily suggesting the MPS as the problem, but ANY time Djet runs rich, check the MPS because a bad diaphragm or leaky hose/connection is a common cause of running rich! I can't think of another test that takes two seconds that tells so much about fuel mixture. IF it didn't change, it would have absolutely been MPS (or not) in 2 seconds! Always do the quick tests to quickly rule things out in early troubleshooting! |
| rjames |
Aug 24 2021, 09:48 PM
What was the difference in idle when you pulled the hose off at the MPS? Just give me that. Would it even run? IIRC, pulling the hose off would just cause it to go super lean, so if it ran I guess it would tell you that something else in the system is causing an uber rich condition, but it wouldn't rule out the MPS as a contributor. If it doesn't run, what would that tell us? If it's an intermittent issue or doesn't happen until the car warms up a little (I'm still not clear if that is the case here) then it's probably not the MPS. I haven't run across intermittent issues, or issues that happen only when the engine is cold or only when warm that ended up being the MPS. Seems like when it's the MPS that's the problem, the symptoms there all the time. Pulling the MPS hose does NOT cause lean, it causes full RICH. True, it should not run, it should immediately choke and die. I wasn't necessarily suggesting the MPS as the problem, but ANY time Djet runs rich, check the MPS because it's so easy (and a bad diaphragm will absolutely cause rich running). I can't think of another test that takes two seconds that tells so much about fuel mixture. IF it didn't change, it would have absolutely been MPS in 2 seconds! Always do the quick tests to quickly rule things out in early troubleshooting! Yup- I had it backwards. After all the DJet and MPS troubleshooting I’ve done in the last two years I don’t know how I got that one wrong! (IMG:style_emoticons/default/unsure.gif) |
| Rand |
Aug 24 2021, 09:52 PM
Yup- I had it backwards. After all the DJet and MPS troubleshooting I’ve done in the last two years I don’t know how I got that one wrong! (IMG:style_emoticons/default/unsure.gif) We've all gotten things wrong. My biggest point, is quick troubleshooting. I've seen people spend hours chasing rabbit trails that could have been ruled out in seconds! It hurts every time. PS: Checking out your music (IMG:style_emoticons/default/smile.gif) |
Halfnelson Help - Djet running way too rich Jul 23 2021, 06:51 AM
rfinegan Try adjusting the Idle mixture knob on the ECU. I ... Jul 23 2021, 07:35 AM
jrmdir Welcome to the D-Jet rich mixture madness. I'm... Jul 23 2021, 08:19 AM
dr914@autoatlanta.com SUPER rich could be blocked fuel return, bad valve... Jul 23 2021, 08:46 AM
ctc911ctc That is a beautiful car!
SUPER rich could ... Jul 23 2021, 09:43 AM
Olympic 914 Pull a vacuum on your MPS
Make sure your diaphragm... Jul 23 2021, 11:11 AM
rjames
Make sure your diaphrag... Jul 23 2021, 12:02 PM
Dave_Darling Step 1: Check the ignition system. Yes, seriousl... Jul 24 2021, 01:05 AM
Halfnelson Many thanks for all the suggestions - plenty to wo... Jul 24 2021, 07:44 AM
jrmdir Hi Halfnelson: Hope this doesn't amount to hij... Jul 24 2021, 10:05 AM
rjames Calibrating the MPS correctly requires being able ... Jul 24 2021, 10:19 AM
brant
Calibrating the MPS correctly requires being able... Jul 24 2021, 01:09 PM
mgphoto
Calibrating the MPS correctly requires being able... Sep 6 2022, 01:00 PM
jrmdir Thanks for the feedback. Just to be clear, I'm... Jul 24 2021, 02:14 PM
Dave_Darling Also worth checking the fuel pressure. Should be ... Jul 24 2021, 07:20 PM
r_towle Clean the inner parts in the distributor.
The adva... Jul 24 2021, 09:39 PM
Halfnelson Thanks for everyone's feedback on this. I... Aug 11 2021, 08:45 AM
Rand I would have bet MPS. How was it tested?
A simple... Aug 11 2021, 06:30 PM
Halfnelson OK - so not sorted after all. :headbang:
After ... Aug 20 2021, 07:53 AM
Bartlett 914
After... Aug 20 2021, 07:58 AM
Halfnelson Thanks Mark - have replaced the CHT but will test ... Aug 20 2021, 09:34 AM
rjames I had a similar situation and it turned out to be ... Aug 20 2021, 09:35 AM
Halfnelson
I had a similar situation and it turned out to be... Aug 20 2021, 09:54 AM
rjames
I had a similar situation and it turned out to b... Aug 20 2021, 10:15 AM
emerygt350 Just out of curiosity, have you checked which inje... Aug 20 2021, 04:44 PM
Halfnelson
Just out of curiosity, have you checked which inj... Aug 23 2021, 07:57 AM
Halfnelson Lots of questions spring to mind like how it was e... Aug 23 2021, 08:02 AM
emerygt350 I have 1... And it is yellow.
I bought those n... Aug 23 2021, 06:19 PM
emerygt350
The left side is the 2.0 Aug 23 2021, 06:27 PM
steuspeed Wrong injectors.. amazing! I bought a set of S... Aug 23 2021, 10:34 PM
ChrisFoley Those look like 1.8L injectors, for L-Jet. Someone... Aug 24 2021, 09:52 AM
Halfnelson
Those look like 1.8L injectors, for L-Jet. Someon... Aug 25 2021, 09:37 AM
emerygt350 Wow, the plot thickens. Aug 24 2021, 11:23 AM
emerygt350 The one you are looking for is the fj114. 59 doll... Aug 25 2021, 10:09 AM
Halfnelson I'm resurrecting this thread if that's ok ... Sep 6 2022, 10:10 AM
JeffBowlsby Have you checked your CSV for leakage? Sep 6 2022, 10:30 AM
JamesM
:agree:... Sep 6 2022, 11:52 AM
Halfnelson
:agree... Sep 6 2022, 12:57 PM
rjames I spent well over a year troubleshooting a similar... Sep 6 2022, 11:19 AM
emerygt350 Yeah, check that cold start valve.
Any chance you... Sep 6 2022, 01:01 PM
Halfnelson
Any chance yo... Sep 6 2022, 01:07 PM
Lockwodo
Any chance y... Sep 7 2022, 04:38 PM
emerygt350
[quote name='Halfnelson' post='3027513' date='Sep... Sep 7 2022, 05:30 PM
mgphoto Pull one side of the fuel rail off while the engin... Sep 6 2022, 01:10 PM
emerygt350
Pull one side of the fuel rail off while the engi... Sep 6 2022, 01:38 PM
JeffBowlsby Two other things to check:
TS2 - cyl head temp se... Sep 6 2022, 01:53 PM
rjames
@emerygt350 Not true. What he is experiencing ... Sep 6 2022, 02:24 PM
emerygt350
[b]@[url=http://www.914world.com/bbs2/index.ph... Sep 6 2022, 02:40 PM
rjames
[b]@[url=http://www.914world.com/bbs2/index.p... Sep 6 2022, 03:00 PM
emerygt350 I guess there is no reason it couldn't go outs... Sep 6 2022, 07:00 PM
914_teener Time Out.
There is a difference between testing a... Sep 7 2022, 07:43 PM
Halfnelson Finally got a chance to get to the 914 so can conf... Sep 18 2022, 11:42 AM
emerygt350 Possibly but they look ok. Sep 18 2022, 05:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:28 PM |
