Big 914 that will not idle, Idle Issue |
joeannwh8 |
Aug 22 2019, 03:40 PM
Newbie Group: Members Posts: 8 Joined: 22-August 19 From: Santa Clarita Member No.: 23,398 Region Association: Southern California |
I have a 72 914 that I have been working on forever, started a rebuild 15 years ago. A local machinist help me out and somehow the engine that I thought was a little bigger then 2.1L, I now calculate the size at 2366 cc (103mm x 71mm)! It has an electronic vacuum advance distributor and Solex H32/34 PD513 carbs, compression is 150 psi plus or minus 2 psi all around. Engine starts instantly warm or cold, rev's sluggishly but will quickly get to 6000 rpm easily. The issue is it will not idle below 2200 rpm.
What have I missed? |
joeannwh8 |
Aug 31 2021, 04:38 PM
Okay thanks to everyone that has gotten me this far! The car runs now and stops now!
The running issue was to small carbs and a flaky ignition unit, the no stoppy issue was the rear brake proportional valve set to low (operator error) The issue now is the oil over heats very quickly, 20 minutes driving around town (Santa Clarita CA) on an 80 degree day, 10 minutes on a 100 degree day. The motor is a type 4, 2.3L, 10.5:1 compression, mild cam, weber 44 carbs (set-up by AirCooled.net), somewhere a long the way, (I started working on this motor in 2003), I got talked into a 30mm oil pump (I think this is the issue). My plugs look like hot coco and my heads are running 240, top of engine case 250, bottom of engine case 240, oil temperature on VDO gauge 275; all temps are deg F and recorded with a laser thermometer. I ran 20w-50, switched to 5w-30 and just tried 0w-20, all with similar results cold oil pressure approaching 70 psi @2800 rpm, 50 psi @ 800 rpm, as the oil temp goes up, on the way to 275, the oil pressure starts dropping (dah!) @ idle looks like 5-6 psi @ 2800 rpm 20-40 psi. Am I just over whelming the stock relief system and heating the oil by running it over the reliefs? I experienced this in a very different hydraulic system many years ago. Do I replace the pump or is there a way to lower the pressure (oil volume) with out running the oil over the relief valves??? Do I have to find a stock pump, I think they are 24 mm or will a 26 mm unit lower the volume enough to get my temp's under control. |
HansJan |
Aug 31 2021, 09:24 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Okay thanks to everyone that has gotten me this far! The car runs now and stops now! The running issue was to small carbs and a flaky ignition unit, the no stoppy issue was the rear brake proportional valve set to low (operator error) The issue now is the oil over heats very quickly, 20 minutes driving around town (Santa Clarita CA) on an 80 degree day, 10 minutes on a 100 degree day. The motor is a type 4, 2.3L, 10.5:1 compression, mild cam, weber 44 carbs (set-up by AirCooled.net), somewhere a long the way, (I started working on this motor in 2003), I got talked into a 30mm oil pump (I think this is the issue). My plugs look like hot coco and my heads are running 240, top of engine case 250, bottom of engine case 240, oil temperature on VDO gauge 275; all temps are deg F and recorded with a laser thermometer. I ran 20w-50, switched to 5w-30 and just tried 0w-20, all with similar results cold oil pressure approaching 70 psi @2800 rpm, 50 psi @ 800 rpm, as the oil temp goes up, on the way to 275, the oil pressure starts dropping (dah!) @ idle looks like 5-6 psi @ 2800 rpm 20-40 psi. Am I just over whelming the stock relief system and heating the oil by running it over the reliefs? I experienced this in a very different hydraulic system many years ago. Do I replace the pump or is there a way to lower the pressure (oil volume) with out running the oil over the relief valves??? Do I have to find a stock pump, I think they are 24 mm or will a 26 mm unit lower the volume enough to get my temp's under control. Yours and mine have a similar setup (cylinder and carb wise), but I have an external oil-cooler with electric fan installed underneath the rear trunk. Temps never exceed 220 deg, even in Houston's crazy temps. Also have the oil-bypass thingy from Tangerine installed. BTW: Could you share the jet sizes (my car runs powerful, but sneezes and backfires a little on decel and low neighborhood speed). |
Lo-Fi Version | Time is now: 11th June 2024 - 11:30 AM |
