| jim_hoyland |
Sep 8 2021, 07:19 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,142 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
How is that valve removed from under the cowling. My plan is to pull the gas tank for better access first; then replace the driver side heat/defrost valve. The re-install the control cables.
Any tips will be appreciated… ( see sample photo, not my car ) Attached image(s)
| barefoot |
Sep 8 2021, 02:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,559 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
In re-installing mine, I ground a chamfer on the front bottom of the mixer valve & was able to install with the defrost duct attached. Also remove the little brace next to the mixer & push up on the cowl with a helper.
jim_hoyland Heat/Defrost Mixer Valve Removal Sep 8 2021, 07:19 AM
barefoot This might help: Be very careful
https://914elec... Sep 8 2021, 07:46 AM
jim_hoyland
https://914ele... Sep 8 2021, 09:20 AM
914werke [quote name='barefoot' post='2943849' date='Sep 8... Sep 8 2021, 10:14 AM
IronHillRestorations +1 on extreme care with old plastic parts.
You al... Sep 8 2021, 10:44 AM
jim_hoyland No problem with the cables: they are sorted out.I ... Sep 8 2021, 11:51 AM
914werke Correct, under the dash are a pair of ovid vents. ... Sep 8 2021, 12:16 PM
jim_hoyland
In re-installing mine, I ground a chamfer on the ... Sep 8 2021, 03:36 PM
jim_hoyland Got the valve out, came out pretty easy. The hard ... Sep 14 2021, 04:15 PM
914_teener Hey Jim.......
I'm in Moab for the next week... Sep 14 2021, 04:19 PM
jim_hoyland
Hey Jim.......
I'm in Moab for the next wee... Sep 14 2021, 06:34 PM
PanelBilly If I can remember correctly fly I attached the con... Sep 14 2021, 09:52 PM
DRPHIL914
How is that valve removed from under the cowling.... Sep 15 2021, 12:11 PM
jim_hoyland
How is that valve removed from under the cowling... Sep 16 2021, 04:04 AM
Rob-O Beyond the loosening of the two bolts that hold th... Sep 16 2021, 05:00 PM
jim_hoyland
Beyond the loosening of the two bolts that hold t... Sep 16 2021, 05:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th October 2026 - 06:28 AM |
