> Turn indicator & brake light continuous flashing, Started with a bad bulb
bzettner
post Sep 12 2021, 08:02 AM
'73 1.7, driving along (IMG:style_emoticons/default/driving.gif) both dash turn indicator lights and brake light started flashing continuously (IMG:style_emoticons/default/WTF.gif) . Found out I had a burned out turn signal bulb. Did my 914World searching and learned the flashing is to "let you know" you have a bulb out, great! Changed out the bulb, flashing continues. Cleaned light socket contacts, bulb ends, changed out bulbs in matched pairs, replaced flasher unit with new RockAuto unit, still continual flashing. Added a little brake fluid, no change.
All my lights work as designed, all of them. Dash turn indicators are bright and work individually when used. The new flasher unit causes the dash indicators to flash continually dimmer than the original unit.
I have found a white w green strip wire near the flasher unit that has no connection, no fitting, just a blunt cut wire with no obvious "answer" to its placement. I am NOT a great schematic guy (IMG:style_emoticons/default/headbang.gif) . Something changed! Ideas?
bzettner   Turn indicator & brake light continuous flashing   Sep 12 2021, 08:02 AM
bzettner   Update, I dug and found the other end of the white...   Sep 12 2021, 07:40 PM
Spoke   Update, I dug and found the other end of the whit...   Sep 14 2021, 04:26 AM
bzettner   Update, I dug and found the other end of the whi...   Sep 14 2021, 06:42 AM
Spoke   When you say the turn signal indicators flash cont...   Sep 13 2021, 03:55 PM
bzettner   When you say the turn signal indicators flash con...   Sep 13 2021, 09:31 PM
Spoke   When you say the turn signal indicators flash co...   Sep 14 2021, 04:40 AM
bzettner   The flasher should only operate when there's a...   Sep 14 2021, 06:49 AM
bzettner   [quote name='bzettner' post='2945257' date='Sep 1...   Sep 14 2021, 08:15 PM
Spoke   I disconnected the master cyl switch wires and t...   Sep 15 2021, 04:48 AM
bzettner   I disconnected the master cyl switch wires and ...   Sep 15 2021, 06:39 AM
Spoke   [quote name='Spoke' post='2945612' date='Sep 15 2...   Sep 15 2021, 10:42 AM
Spoke   '73 1.7, driving along :driving: both dash ...   Sep 14 2021, 04:46 AM
bzettner   @[url=http://www.914world.com/bbs2/index.php?s...   Sep 15 2021, 04:36 PM
Spoke   [b]@[url=http://www.914world.com/bbs2/index.p...   Sep 16 2021, 04:39 AM
bzettner   @spoke It’s been a long day and I’m out of t...   Sep 16 2021, 07:22 PM
Spoke   Thanks for the picture. Looks like you're on t...   Sep 16 2021, 09:09 PM
bzettner   Thanks, @spoke . I’ll let you know what the out...   Sep 16 2021, 10:02 PM
bzettner   :Qarl: My new 914Rubber, single spade, resettable ...   Sep 21 2021, 06:43 PM
- Lo-Fi Version Time is now: 31st October 2026 - 02:51 AM
