| bzettner |
Sep 12 2021, 08:02 AM
Member ![]() ![]() Group: Members Posts: 222 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
'73 1.7, driving along (IMG:style_emoticons/default/driving.gif) both dash turn indicator lights and brake light started flashing continuously (IMG:style_emoticons/default/WTF.gif) . Found out I had a burned out turn signal bulb. Did my 914World searching and learned the flashing is to "let you know" you have a bulb out, great! Changed out the bulb, flashing continues. Cleaned light socket contacts, bulb ends, changed out bulbs in matched pairs, replaced flasher unit with new RockAuto unit, still continual flashing. Added a little brake fluid, no change.
All my lights work as designed, all of them. Dash turn indicators are bright and work individually when used. The new flasher unit causes the dash indicators to flash continually dimmer than the original unit. I have found a white w green strip wire near the flasher unit that has no connection, no fitting, just a blunt cut wire with no obvious "answer" to its placement. I am NOT a great schematic guy (IMG:style_emoticons/default/headbang.gif) . Something changed! Ideas? Attached thumbnail(s) |
| bzettner |
Sep 12 2021, 07:40 PM
Update, I dug and found the other end of the white w green wire, connected and the flashing brake light stops (works like its supposed to) The wiring diagram shows that wire going from the light switch to the speedo. I certainly don't see it going into the back of the speedo. Not sure where it ends up as it nestled well in the dash harness.
Still have the continuous flashing turn indicators in the dash. Everything works as it should except the flashing indicators. @spoke |
bzettner Turn indicator & brake light continuous flashing Sep 12 2021, 08:02 AM
Spoke
Update, I dug and found the other end of the whit... Sep 14 2021, 04:26 AM
bzettner
Update, I dug and found the other end of the whi... Sep 14 2021, 06:42 AM
Spoke When you say the turn signal indicators flash cont... Sep 13 2021, 03:55 PM
bzettner
When you say the turn signal indicators flash con... Sep 13 2021, 09:31 PM
Spoke
When you say the turn signal indicators flash co... Sep 14 2021, 04:40 AM
bzettner The flasher should only operate when there's a... Sep 14 2021, 06:49 AM
bzettner
[quote name='bzettner' post='2945257' date='Sep 1... Sep 14 2021, 08:15 PM
Spoke
I disconnected the master cyl switch wires and t... Sep 15 2021, 04:48 AM
bzettner
I disconnected the master cyl switch wires and ... Sep 15 2021, 06:39 AM
Spoke
[quote name='Spoke' post='2945612' date='Sep 15 2... Sep 15 2021, 10:42 AM
Spoke
'73 1.7, driving along :driving: both dash ... Sep 14 2021, 04:46 AM
bzettner
@[url=http://www.914world.com/bbs2/index.php?s... Sep 15 2021, 04:36 PM
Spoke
[b]@[url=http://www.914world.com/bbs2/index.p... Sep 16 2021, 04:39 AM
bzettner @spoke
It’s been a long day and I’m out of t... Sep 16 2021, 07:22 PM
Spoke Thanks for the picture. Looks like you're on t... Sep 16 2021, 09:09 PM
bzettner Thanks, @spoke . I’ll let you know what the out... Sep 16 2021, 10:02 PM
bzettner :Qarl: My new 914Rubber, single spade, resettable ... Sep 21 2021, 06:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 31st October 2026 - 02:54 AM |
