CV joint help needed please, bearings out of position - fell out now what? |
DRPHIL914 |
Sep 13 2021, 03:20 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
so while installing the motor and transmission yesterday- and it seemed to go so smooth, the cv and axle got out of position, the inner must have gotten bumped and twisted , so i was just now trying to get the one that fell out back in , but also noticed they if i spin the axle the outer one is kind of off center as well, so now i am wondering if i am going to have to pull the whole axle to get these put back in the cage and on the axle?? seems like i will have to pull the whole assembly, to get them circlip off and put it all back together properly—-
pandora’s box here - opening a can of worms- i have to put it on the ground to take off the outer axle nut, then pull the shaft right? looks like there is not enough room to pull it with He in and that will have to be pulled too! - can i leave the other side all hooked up? Advice please!! Phil |
jcd914 |
Sep 14 2021, 12:56 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I think that discoloration is from the heat treating process of the machined bearing surface, I have seen it on other brand new CV joints. Have not looked at a new or old 914 CV for some time.
Jim |
Lo-Fi Version | Time is now: 9th June 2024 - 11:41 AM |
