| bzettner |
Sep 12 2021, 08:02 AM
Member ![]() ![]() Group: Members Posts: 222 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
'73 1.7, driving along (IMG:style_emoticons/default/driving.gif) both dash turn indicator lights and brake light started flashing continuously (IMG:style_emoticons/default/WTF.gif) . Found out I had a burned out turn signal bulb. Did my 914World searching and learned the flashing is to "let you know" you have a bulb out, great! Changed out the bulb, flashing continues. Cleaned light socket contacts, bulb ends, changed out bulbs in matched pairs, replaced flasher unit with new RockAuto unit, still continual flashing. Added a little brake fluid, no change.
All my lights work as designed, all of them. Dash turn indicators are bright and work individually when used. The new flasher unit causes the dash indicators to flash continually dimmer than the original unit. I have found a white w green strip wire near the flasher unit that has no connection, no fitting, just a blunt cut wire with no obvious "answer" to its placement. I am NOT a great schematic guy (IMG:style_emoticons/default/headbang.gif) . Something changed! Ideas? Attached thumbnail(s) |
| Spoke |
Sep 13 2021, 03:55 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,436 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
When you say the turn signal indicators flash continuously is this with the key on and no turn signals on? Both flash?
| bzettner |
Sep 13 2021, 09:31 PM
When you say the turn signal indicators flash continuously is this with the key on and no turn signals on? Both flash? Yes, start the car, shut the door, release the E-brake (stops the red flashing brake light) and the dash turn signal indicator lights both blink at the same time, continuously. If you put on the right or left blinker, they work like they should until the blinker is turned off. Besides this, all lights, flashers, turn signals brake light, tail lights, hi/lo headlights and aftermarket fog lights all work as they have since 2013 when I got this car. |
| Spoke |
Sep 14 2021, 04:40 AM
When you say the turn signal indicators flash continuously is this with the key on and no turn signals on? Both flash? Yes, start the car, shut the door, release the E-brake (stops the red flashing brake light) and the dash turn signal indicator lights both blink at the same time, continuously. If you put on the right or left blinker, they work like they should until the blinker is turned off. Besides this, all lights, flashers, turn signals brake light, tail lights, hi/lo headlights and aftermarket fog lights all work as they have since 2013 when I got this car. It is strange that the turnsignal indicators flash since there's a 2nd relay in the flasher to detect heavy exterior bulb current to power the indicators on pin K on the flasher. The flasher should only operate when there's a load on terminal 49a. In the diagram, the only paths to ground are the 4-way switch, turnsignal switch or brake warning indicator. One test is to remove the wires on the master cylinder warning switch under the car and the ebrake wires. Something is creating a load or leakage on terminal 49a. If the new flasher didn't solve the issue then the original flasher should be ok and should be reinstalled. While the flasher is out, measure the resistance from the plug terminal 49a to ground. It should be infinite since every path to ground goes through a switch thus should be an open circuit. Attached image(s)
| bzettner |
Sep 14 2021, 08:15 PM
When you say the turn signal indicators flash continuously is this with the key on and no turn signals on? Both flash? Yes, start the car, shut the door, release the E-brake (stops the red flashing brake light) and the dash turn signal indicator lights both blink at the same time, continuously. If you put on the right or left blinker, they work like they should until the blinker is turned off. Besides this, all lights, flashers, turn signals brake light, tail lights, hi/lo headlights and aftermarket fog lights all work as they have since 2013 when I got this car. It is strange that the turnsignal indicators flash since there's a 2nd relay in the flasher to detect heavy exterior bulb current to power the indicators on pin K on the flasher. The flasher should only operate when there's a load on terminal 49a. In the diagram, the only paths to ground are the 4-way switch, turnsignal switch or brake warning indicator. One test is to remove the wires on the master cylinder warning switch under the car and the ebrake wires. Something is creating a load or leakage on terminal 49a. If the new flasher didn't solve the issue then the original flasher should be ok and should be reinstalled. While the flasher is out, measure the resistance from the plug terminal 49a to ground. It should be infinite since every path to ground goes through a switch thus should be an open circuit. I disconnected the master cyl switch wires and the e-brake wire. This indeed eliminates the dash indicators blinking, The e-brake female wire connector was falling apart. I replaced the female spade connector and feel all is well there. There is quite a bit of resistance from 49a to ground. My next "look into" will be tracing the wires from the master cyl switch towards the dash to see if there is an apparent "bad spot"....hoping for something obvious (IMG:style_emoticons/default/wacko.gif) |
| Spoke |
Sep 15 2021, 04:48 AM
I disconnected the master cyl switch wires and the e-brake wire. This indeed eliminates the dash indicators blinking, The e-brake female wire connector was falling apart. I replaced the female spade connector and feel all is well there. There is quite a bit of resistance from 49a to ground. My next "look into" will be tracing the wires from the master cyl switch towards the dash to see if there is an apparent "bad spot"....hoping for something obvious (IMG:style_emoticons/default/wacko.gif) @bzettner So the flasher circuit is working correctly now with the master cylinder switch wire disconnected from the switch? Having quite a bit of resistance from 49a to ground is good. |
| bzettner |
Sep 15 2021, 06:39 AM
I disconnected the master cyl switch wires and the e-brake wire. This indeed eliminates the dash indicators blinking, The e-brake female wire connector was falling apart. I replaced the female spade connector and feel all is well there. There is quite a bit of resistance from 49a to ground. My next "look into" will be tracing the wires from the master cyl switch towards the dash to see if there is an apparent "bad spot"....hoping for something obvious (IMG:style_emoticons/default/wacko.gif) @bzettner So the flasher circuit is working correctly now with the master cylinder switch wire disconnected from the switch? Having quite a bit of resistance from 49a to ground is good. Yes, with the MC switch disconnected, everything works as designed EXCEPT any advantage of having the MC switch working, yes? I'm confused, I understood that 49a to ground should be infinity/zero resistance. Now I'm reading a lot of resistance is good. I'm a ignorant/learning electrical 914 guy, which is it? And, am I right to think there is a short to ground somewhere from the MC switch wires to the flasher plug? Your help is very much appreciated, @Spoke ! (IMG:style_emoticons/default/beerchug.gif) |
bzettner Turn indicator & brake light continuous flashing Sep 12 2021, 08:02 AM
bzettner Update, I dug and found the other end of the white... Sep 12 2021, 07:40 PM
Spoke
Update, I dug and found the other end of the whit... Sep 14 2021, 04:26 AM
bzettner
Update, I dug and found the other end of the whi... Sep 14 2021, 06:42 AM
bzettner The flasher should only operate when there's a... Sep 14 2021, 06:49 AM
Spoke
[quote name='Spoke' post='2945612' date='Sep 15 2... Sep 15 2021, 10:42 AM
Spoke
'73 1.7, driving along :driving: both dash ... Sep 14 2021, 04:46 AM
bzettner
@[url=http://www.914world.com/bbs2/index.php?s... Sep 15 2021, 04:36 PM
Spoke
[b]@[url=http://www.914world.com/bbs2/index.p... Sep 16 2021, 04:39 AM
bzettner @spoke
It’s been a long day and I’m out of t... Sep 16 2021, 07:22 PM
Spoke Thanks for the picture. Looks like you're on t... Sep 16 2021, 09:09 PM
bzettner Thanks, @spoke . I’ll let you know what the out... Sep 16 2021, 10:02 PM
bzettner :Qarl: My new 914Rubber, single spade, resettable ... Sep 21 2021, 06:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 31st October 2026 - 02:52 AM |
