> Strong Fuel Smell, Is it normal...
Rick986
post Sep 15 2021, 01:27 PM
0-60 in 14 seconds!
...to be getting a fairly strong fuel smell in the frunk? I can smell it pretty good in the garage. Having the car inspected Friday but just wondering if this is typical. Thanks!
brant
post Sep 15 2021, 01:50 PM
some times its simple... a bad gasket at the filler neck
or sometimes a hose under the tank (do you know when those were last replaced?... I like to change mine out every 5-6 years)
sometimes its a pin hole in the tank itself... they tend to rust through from the inside, often where the soft pads are that the tank mounts on.
If you had just filled it... and maybe overfilled it to the very top... they can smell a little due to being overfilled.
rmital
post Sep 15 2021, 01:57 PM
Northeast optimist
QUOTE(brant @ Sep 15 2021, 03:50 PM) *
he just got the car....my money's on filling it to the brim. smelly.... (IMG:style_emoticons/default/icon8.gif)
GregAmy
post Sep 15 2021, 02:32 PM
QUOTE(rmital @ Sep 15 2021, 03:57 PM) *
Ditto. Mine was a rust hole behind the carpet/pad that manifested itself when I filled up the tank...and it ended up pouring onto the garage floor.
Rick986   Strong Fuel Smell   Sep 15 2021, 01:27 PM
rmital   ...to be getting a fairly strong fuel smell in th...   Sep 15 2021, 01:35 PM
Rick986   ...to be getting a fairly strong fuel smell in t...   Sep 15 2021, 02:54 PM
mepstein   No, It is not normal.   Sep 15 2021, 01:42 PM
Jamie   No, It is not normal. You have a leak to track d...   Sep 15 2021, 01:43 PM
brant   some times its simple... a bad gasket at the fille...   Sep 15 2021, 01:50 PM
rmital   If you had just filled it... and maybe overfille...   Sep 15 2021, 01:57 PM
GregAmy   he just got the car....my money's on filling ...   Sep 15 2021, 02:32 PM
r_towle   If you had just filled it... and maybe overfill...   Sep 15 2021, 02:43 PM
bbrock   If you had just filled it... and maybe overfill...   Sep 15 2021, 04:03 PM
Rick986   Service records show fuel tank, sender & fluid...   Sep 15 2021, 03:02 PM
porschetub   Service records show fuel tank, sender & flui...   Sep 15 2021, 03:21 PM
lierofox   Service records show fuel tank, sender & flu...   Sep 15 2021, 03:30 PM
bretth   Be very careful if you have a gas hot water heater...   Sep 15 2021, 03:05 PM
Cairo94507   It's concerning when you get that strong gas s...   Sep 15 2021, 03:28 PM
brant   as a new owner... its worth telling you in case yo...   Sep 15 2021, 04:03 PM
r_towle   I would do it so you know they are new and they ar...   Sep 15 2021, 06:10 PM
rmital   If not that, there is a charcoal venting system,...   Sep 16 2021, 08:07 AM
ClayPerrine   If not that, there is a charcoal venting system...   Sep 16 2021, 09:34 AM
mepstein   In some cases, the tank has rusted through and has...   Sep 15 2021, 06:30 PM
FlacaProductions   I'd try the gas cap seal. https://914rubber....   Sep 16 2021, 09:18 AM
Craigers17   If your car is fuel injected, and you're comfo...   Sep 16 2021, 09:35 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:47 PM
