> Strong Fuel Smell, Is it normal...
Rick986
post Sep 15 2021, 01:27 PM
0-60 in 14 seconds!
...to be getting a fairly strong fuel smell in the frunk? I can smell it pretty good in the garage. Having the car inspected Friday but just wondering if this is typical. Thanks!
Rick986
post Sep 15 2021, 03:02 PM
0-60 in 14 seconds!
Service records show fuel tank, sender & fluid...along with all hoses were replaced in 2009 - 4,000 miles ago. Sounds like those hoses should be replaced, at a minimum...
porschetub
post Sep 15 2021, 03:21 PM
QUOTE(Rick986 @ Sep 16 2021, 09:02 AM) *
Yes that would be a good idea,filler neck gasket as mentioned and don't forget the gas cap seal there are 2 types year dependant,if you have the plastic cap don't buy the cardboard seal like I bought from Pelican....pretty much useless after a while.
914rubber should all or most of the parts you need,good luck.
Rick986   Strong Fuel Smell   Sep 15 2021, 01:27 PM
rmital   ...to be getting a fairly strong fuel smell in th...   Sep 15 2021, 01:35 PM
Rick986   ...to be getting a fairly strong fuel smell in t...   Sep 15 2021, 02:54 PM
mepstein   No, It is not normal.   Sep 15 2021, 01:42 PM
Jamie   No, It is not normal. You have a leak to track d...   Sep 15 2021, 01:43 PM
brant   some times its simple... a bad gasket at the fille...   Sep 15 2021, 01:50 PM
rmital   If you had just filled it... and maybe overfille...   Sep 15 2021, 01:57 PM
GregAmy   he just got the car....my money's on filling ...   Sep 15 2021, 02:32 PM
r_towle   If you had just filled it... and maybe overfill...   Sep 15 2021, 02:43 PM
bbrock   If you had just filled it... and maybe overfill...   Sep 15 2021, 04:03 PM
Rick986   Service records show fuel tank, sender & fluid...   Sep 15 2021, 03:02 PM
porschetub   Service records show fuel tank, sender & flui...   Sep 15 2021, 03:21 PM
lierofox   Service records show fuel tank, sender & flu...   Sep 15 2021, 03:30 PM
bretth   Be very careful if you have a gas hot water heater...   Sep 15 2021, 03:05 PM
Cairo94507   It's concerning when you get that strong gas s...   Sep 15 2021, 03:28 PM
brant   as a new owner... its worth telling you in case yo...   Sep 15 2021, 04:03 PM
r_towle   I would do it so you know they are new and they ar...   Sep 15 2021, 06:10 PM
rmital   If not that, there is a charcoal venting system,...   Sep 16 2021, 08:07 AM
ClayPerrine   If not that, there is a charcoal venting system...   Sep 16 2021, 09:34 AM
mepstein   In some cases, the tank has rusted through and has...   Sep 15 2021, 06:30 PM
FlacaProductions   I'd try the gas cap seal. https://914rubber....   Sep 16 2021, 09:18 AM
Craigers17   If your car is fuel injected, and you're comfo...   Sep 16 2021, 09:35 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:14 PM
