Best 914-6 engine mount |
David Stowers |
Sep 15 2021, 10:53 AM
Member Group: Members Posts: 99 Joined: 28-June 12 From: UK Member No.: 14,613 Region Association: None |
Hi Guys
I need to choose an engine mount for my conversion. Any pros and cons of which type to go for? I understand height on install is an issue to get a good air seal to avoid overheating issues Thanks |
brant |
Sep 15 2021, 11:12 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the PMS tilting mount has the advantage of easier motor install/removal, and also tipping for service work. may not be as important for a street car. but very helpful on a race car.
Justinp71 |
Sep 15 2021, 11:21 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
the PMS tilting mount has the advantage of easier motor install/removal, and also tipping for service work. may not be as important for a street car. but very helpful on a race car. Is this bolt or weld on? I went with Rich Johnson because it was both (weld and bolt) I thought was was a nice way to go. Just have to remove the rear brake lock up device. |
brant |
Sep 15 2021, 12:28 PM
the PMS tilting mount has the advantage of easier motor install/removal, and also tipping for service work. may not be as important for a street car. but very helpful on a race car. Is this bolt or weld on? I went with Rich Johnson because it was both (weld and bolt) I thought was was a nice way to go. Just have to remove the rear brake lock up device. Mines welded I assume they all are? |
Justinp71 |
Sep 15 2021, 05:57 PM
the PMS tilting mount has the advantage of easier motor install/removal, and also tipping for service work. may not be as important for a street car. but very helpful on a race car. Is this bolt or weld on? I went with Rich Johnson because it was both (weld and bolt) I thought was was a nice way to go. Just have to remove the rear brake lock up device. Mines welded I assume they all are? The Rich Johnson is both. So you have about 4 thru bolts as I recall that take some of the load thru the firewall and its also stitch welded. I personally liked this as an extra safety measure. |
Lo-Fi Version | Time is now: 20th May 2024 - 01:18 PM |
