> If you built a 2056
Geezer914
post Sep 15 2021, 05:04 PM
Geezer914
I just built a 2056 and had a number of no start issues, I finally got the engine to start. but it looks like I wiped out the cam. So I have to start over with a complete tear down and cleaning of the block and the internals. (IMG:style_emoticons/default/headbang.gif)
My question is with determining push rod length: Are you measuring the length of each push rod, or measuring the #1 intake and exhaust and cutting all the intake and all the exhaust push rods the same length? With turning the engine over and over by hand to get the correct push rod lengths you would assume it has wiped all the assembly lube off the cam lobes before you start the engine. (IMG:style_emoticons/default/WTF.gif) I sure as hell don't want this to happen again.
Geezer914
post Sep 15 2021, 06:25 PM
Geezer914
It started out at 80lbs oil pressure and went down to 20 after 20 minutes. I am going to take the oil filter apart and check for debris.
- Lo-Fi Version Time is now: 24th November 2026 - 04:48 AM
