| jim_hoyland |
Sep 8 2021, 07:19 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,142 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
How is that valve removed from under the cowling. My plan is to pull the gas tank for better access first; then replace the driver side heat/defrost valve. The re-install the control cables.
Any tips will be appreciated… ( see sample photo, not my car ) Attached image(s)
| Rob-O |
Sep 16 2021, 05:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,321 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
Beyond the loosening of the two bolts that hold the cowl down, you may also want to remove the four nuts under the cowl that hold the dash on. Then inside the car there are two screws in the area by the door (believe knee pad has to come out to access those) to the sides of the vents (assuming a post ‘72 built car). One other bolt under the dash around the heat/vent controls and the whole dash could be moved quite a bit.
Once the dash is moved upwards (or removed completely) it’s amazing how much space there is in that area. It allows you to tilt that mix valve up without the defrost vent hitting the dash or the bottom part of the valve getting caught in the hole in the firewall. |
jim_hoyland Heat/Defrost Mixer Valve Removal Sep 8 2021, 07:19 AM
barefoot This might help: Be very careful
https://914elec... Sep 8 2021, 07:46 AM
jim_hoyland
https://914ele... Sep 8 2021, 09:20 AM
914werke [quote name='barefoot' post='2943849' date='Sep 8... Sep 8 2021, 10:14 AM
IronHillRestorations +1 on extreme care with old plastic parts.
You al... Sep 8 2021, 10:44 AM
jim_hoyland No problem with the cables: they are sorted out.I ... Sep 8 2021, 11:51 AM
914werke Correct, under the dash are a pair of ovid vents. ... Sep 8 2021, 12:16 PM
barefoot In re-installing mine, I ground a chamfer on the f... Sep 8 2021, 02:08 PM
jim_hoyland
In re-installing mine, I ground a chamfer on the ... Sep 8 2021, 03:36 PM
jim_hoyland Got the valve out, came out pretty easy. The hard ... Sep 14 2021, 04:15 PM
914_teener Hey Jim.......
I'm in Moab for the next week... Sep 14 2021, 04:19 PM
jim_hoyland
Hey Jim.......
I'm in Moab for the next wee... Sep 14 2021, 06:34 PM
PanelBilly If I can remember correctly fly I attached the con... Sep 14 2021, 09:52 PM
DRPHIL914
How is that valve removed from under the cowling.... Sep 15 2021, 12:11 PM
jim_hoyland
How is that valve removed from under the cowling... Sep 16 2021, 04:04 AM
jim_hoyland
Beyond the loosening of the two bolts that hold t... Sep 16 2021, 05:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th October 2026 - 06:30 AM |
