Best 914-6 engine mount |
David Stowers |
Sep 15 2021, 10:53 AM
Member Group: Members Posts: 99 Joined: 28-June 12 From: UK Member No.: 14,613 Region Association: None |
Hi Guys
I need to choose an engine mount for my conversion. Any pros and cons of which type to go for? I understand height on install is an issue to get a good air seal to avoid overheating issues Thanks |
ClayPerrine |
Sep 17 2021, 01:55 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I always wondered why Porsche didn't add the proper mounts to use the 911 crossbar when installing the six in the 914 chassis?
That would put the mounts way farther outboard, and would make it much easier to install and remove the motor. Plus it would mean less parts count in inventory. (IMG:style_emoticons/default/idea.gif) |
mb911 |
Sep 17 2021, 02:41 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I always wondered why Porsche didn't add the proper mounts to use the 911 crossbar when installing the six in the 914 chassis? That would put the mounts way farther outboard, and would make it much easier to install and remove the motor. Plus it would mean less parts count in inventory. (IMG:style_emoticons/default/idea.gif) That's a great point if it would have been engineered for it than all the items I listed would be a non issue. Also Interesting why the heat exchangers were not mirrored |
Steve |
Sep 17 2021, 02:47 PM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I always wondered why Porsche didn't add the proper mounts to use the 911 crossbar when installing the six in the 914 chassis? That would put the mounts way farther outboard, and would make it much easier to install and remove the motor. Plus it would mean less parts count in inventory. (IMG:style_emoticons/default/idea.gif) That's a great point if it would have been engineered for it than all the items I listed would be a non issue. Also Interesting why the heat exchangers were not mirrored If they used the stock 911 bar, would it interfere with the heat exchangers like the cross bar motor mount did. Also the pissing match on using the four cylinder mounts versus moving the drivetrain mount to the firewall. Does it change the center of gravity? |
mepstein |
Sep 17 2021, 03:19 PM
914-6 GT in waiting Group: Members Posts: 19,277 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I always wondered why Porsche didn't add the proper mounts to use the 911 crossbar when installing the six in the 914 chassis? That would put the mounts way farther outboard, and would make it much easier to install and remove the motor. Plus it would mean less parts count in inventory. (IMG:style_emoticons/default/idea.gif) That's a great point if it would have been engineered for it than all the items I listed would be a non issue. Also Interesting why the heat exchangers were not mirrored If they used the stock 911 bar, would it interfere with the heat exchangers like the cross bar motor mount did. Also the pissing match on using the four cylinder mounts versus moving the drivetrain mount to the firewall. Does it change the center of gravity? Center of gravity doesn’t change just by moving a pivot point. |
Lo-Fi Version | Time is now: 20th May 2024 - 04:15 PM |
