| Tdskip |
Sep 20 2021, 01:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,784 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Several twists and turns I’m getting close to getting that XN turbo big bore engine back to me. This is the one that had a very elaborate homebrew turbo set up turns out was only running on three out of four cylinders when I did the initial teardown. I ended up having to swap the case out for another one because when it was rebuilt for the first time it was developing crazy high will pressure hand given all the unknowns and some funkiness with it that we discovered we decided it would be better to just use another case
Shop let me know going in the carbs I gave them would be snappy and responsive but probably leave horsepower on the table. The shop also noted that this was not run using optimized headers and exhaust is probably a bit restrictive for this sort of build. Thing that really jumps out to me here is that the engine is making lotta torch, or at least seems to be a lot of work, down low and had a very usable or p.m. That, to my son white uneducated eyes, suggest that should be fun for regular street use. What do you all think? |
| SirAndy |
Sep 20 2021, 01:12 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,563 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Curious what you all think of this dyno read out? Shift at 4500 rpm for max acceleration ... (IMG:style_emoticons/default/driving.gif) |
Tdskip Curious what you all think of this dyno read out? Sep 20 2021, 01:02 PM
Tdskip
Curious what you all think of this dyno read out... Sep 20 2021, 01:19 PM
Curious what you all think of this dyno read out... Sep 20 2021, 02:15 PM
[quote name='SirAndy' post='2946967' date='Sep 20... Sep 20 2021, 04:18 PM
jd74914 Did you keep the original heads?
Seems like the ... Sep 20 2021, 02:07 PM
rhodyguy What is the displacement of this engine? Still nor... Sep 20 2021, 02:27 PM
Tdskip Thanks for all the responses and discussion. This ... Sep 20 2021, 02:48 PM
VaccaRabite
Thanks for all the responses and discussion. This... Sep 21 2021, 02:31 PM
windforfun https://www.caranddriver.com/news/a15347872...the-... Sep 20 2021, 04:40 PM
Tdskip Thanks - apparently will have the first 914 Diesel... Sep 21 2021, 07:34 AM
Chris914n6 Shop was right about the carbs, you ran out of air... Sep 21 2021, 01:51 PM
rhodyguy Esp if they have 28?MM Venturi. Spring for some he... Sep 21 2021, 01:56 PM
JmuRiz Something is wrong with the graph, how does it not... Sep 22 2021, 07:33 PM
targa72e data is not correct in graph. If you have 162Ft/lb... Sep 22 2021, 07:59 PM
Tdskip
data is not correct in graph. If you have 162Ft/l... Oct 2 2021, 06:06 AM
PlaysWithCars
data is not correct in graph. If you have 162Ft/l... Sep 22 2021, 11:07 PM
Rufus Agree with the others. Something’s fishy about t... Oct 1 2021, 06:11 PM
Rufus
[quote name='Tdskip' post='2946965' date='Sep 20 ... Oct 1 2021, 06:36 PM
Rufus Quoting Tdskip: “… a very elaborate homebrew t... Oct 1 2021, 10:40 PM
Tdskip
Quoting Tdskip: “… a very elaborate homebrew ... Oct 2 2021, 06:01 AM
Gatornapper While we are displaying Dyno readings, anyone have... Oct 2 2021, 06:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 01:54 PM |
