| 930cabman |
Sep 20 2021, 05:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,886 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
It seems like yesterday, but I recall running an engine at WOT for a short time, cutting off the power and coasting to a stop. These days we have air/fuel readers fed information from 02 sensors, with mapping, blah, blah. I suppose some of us older guys have gotten up to speed with tech, but not this guy. Our recent 914 purchase had previously received a Holley 2V carb conversion. It was starting/running decent, but pulled the engine to repair a bad oil leak. The front (hub) seal was loose in the case, so it seems as though I found the oil leak and also decided to pull the plugs for a quick clean. I was pleasantly surprised to find all the plugs a light tan color.
| 930cabman |
Sep 21 2021, 04:25 PM
Might be a task to get this old dog to change, but I am considering either twin Webers or cobbling together a L jet system from several boxes of parts. I know the carbs will work, and I have many concerns with 50 years old parts/sensors/ECU/...
| porschetub |
Sep 22 2021, 04:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,203 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Might be a task to get this old dog to change, but I am considering either twin Webers or cobbling together a L jet system from several boxes of parts. I know the carbs will work, and I have many concerns with 50 years old parts/sensors/ECU/... L-jet is fine as not too much to go wrong,ecu's seem to be pretty robust but the real issue that comes up is the AFM which can be worn out and the air gate (flap) sticks up ,appears to be a few reman units around for reasonable money however. FI looms suffer with the heat but can be repaired,my next build will be with L-jet and I have otherwise good parts except for the AFM which is the reason the last owner of the system went to carbs. Its a good system IMO problem it just came with a really gutless motor (IMG:style_emoticons/default/sad.gif) ,the fact you can bore and stroke the motor and not change the system is good. |
930cabman Does anyone read plugs anymore? Sep 20 2021, 05:37 PM
914e
It seems like yesterday, but I recall running an ... Sep 20 2021, 05:57 PM
930cabman
It seems like yesterday, but I recall running an... Sep 20 2021, 06:02 PM
tom.esh Oh thanks. Now I'm an old guy. Just pulled the... Sep 20 2021, 06:14 PM
Rand No matter the engine control, plug reading never l... Sep 20 2021, 07:30 PM
windforfun
No matter the engine control, plug reading never ... Sep 20 2021, 08:40 PM
Rand All current competitive racers still read plugs... Sep 20 2021, 09:03 PM
930cabman Thanks for the replies, my gut was telling me the ... Sep 21 2021, 12:28 PM
Rand
Thanks for the replies, my gut was telling me the... Sep 21 2021, 03:43 PM
930cabman
Might be a task to get this old dog to change, b... Sep 23 2021, 05:52 PM
Superhawk996
In a couple hours I can have this current build ... Sep 24 2021, 06:40 AM
930cabman
[quote name='930cabman' post='2947721' date='Sep ... Sep 24 2021, 12:10 PM
roblav1 I'm one of those old dogs... been reading plug... Sep 23 2021, 06:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 05:24 AM |
