'75 1.8L Idling at 1,600 RPM -, Vacuum advance on distributor connected and... |
Rick986 |
Sep 17 2021, 04:35 PM
0-60 in 14 seconds! Group: Members Posts: 141 Joined: 31-August 21 From: NE Ohio Member No.: 25,869 Region Association: Upper MidWest |
Had the car in for a post PI today and tech noted that the "vacuum advance" on distributor was not connected when the (previously bad) charcoal canister was removed. He teed into another vacuum line and connected the vacuum port. He noted that this will increase RPM's but will also help with acceleration.
I did notice a slight increase in acceleration but more so, the car is now idling at 1,600 RPM when warm. Seems excessive. Plus, I think that I noticed that the exhaust no longer "pops" when decelerating (which was kinda cool...yet slightly obnoxious). Thoughts? Thanks for educating this Newbie... |
emerygt350 |
Sep 22 2021, 06:32 PM
Advanced Member Group: Members Posts: 2,145 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I don't really know what 'late 74' means but I think the diagrams posted above show the two variants pretty well. Lord knows which you end up with but if you have the ports on the tb it does show you what to do with them.
Although, looking closer, it is interesting that the retard switches ports. That doesn't make sense. |
wonkipop |
Sep 22 2021, 09:13 PM
Advanced Member Group: Members Posts: 4,402 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
I don't really know what 'late 74' means but I think the diagrams posted above show the two variants pretty well. Lord knows which you end up with but if you have the ports on the tb it does show you what to do with them. Although, looking closer, it is interesting that the retard switches ports. That doesn't make sense. yes, something not quite right with diagrams. unless ports exchanged sides on which was an advance and which was a retard port on the two different throttle bodies? i have never seen a single port throttle body - don't know. here is a post i found - dave darling/shop talk forum/20 years ago. my 74 set up agrees with second diagram showing 75 cars except there is no EGR valve. so plumbing hook ups with ts to TB lines and CV line not there. Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 12:53 AM |
